Obi.ObiTearableClothBlueprint Class Reference
Inheritance diagram for Obi.ObiTearableClothBlueprint:
Obi.ObiClothBlueprint Obi.ObiClothBlueprintBase Obi.ObiMeshBasedActorBlueprint Obi.ObiActorBlueprint Obi.IObiParticleCollection
override void CommitBlueprintChanges ()
- Public Member Functions inherited from Obi.ObiClothBlueprint
override void ClearTethers ()
override void GenerateTethers (bool[] selected)
- Public Member Functions inherited from Obi.ObiActorBlueprint
delegate void BlueprintCallback (ObiActorBlueprint blueprint)
bool IsParticleActive (int index)
bool ActivateParticle (int index)
bool DeactivateParticle (int index)
void RecalculateBounds ()
IEnumerable< IObiConstraints > GetConstraints ()
int GetParticleRuntimeIndex (int blueprintIndex)
Vector3 GetParticlePosition (int index)
Quaternion GetParticleOrientation (int index)
Vector3 GetParticleRestPosition (int index)
Quaternion GetParticleRestOrientation (int index)
void GetParticleAnisotropy (int index, ref Vector4 b1, ref Vector4 b2, ref Vector4 b3)
float GetParticleMaxRadius (int index)
Color GetParticleColor (int index)
void GenerateImmediate ()
IEnumerator Generate ()
void Clear ()
ObiParticleGroup InsertNewParticleGroup (string name, int index, bool saveImmediately=true)
ObiParticleGroup AppendNewParticleGroup (string name, bool saveImmediately=true)
bool RemoveParticleGroupAt (int index, bool saveImmediately=true)
bool SetParticleGroupName (int index, string name, bool saveImmediately=true)
void ClearParticleGroups (bool registerUndo=true, bool saveImmediately=true)
virtual void RemoveSelectedParticles (ref bool[] selected, bool optimize=true)
void RestoreRemovedParticles ()
float tearCapacity = 0.5f
float[] tearResistance
Vector2Int[] distanceConstraintMap
- Public Attributes inherited from Obi.ObiClothBlueprint
float vertexWeldDistance = 0.0001f
float minimumParticleSize = 0
- Public Attributes inherited from Obi.ObiClothBlueprintBase
int[] deformableTriangles = null
Vector2[] triangleUVs = null
Vector3[] restNormals = null
float[] areaContribution = null
const float DEFAULT_PARTICLE_MASS = 0.1f
ObiMesh topology => m_Topology
ObiSkinMap defaultSkinmap => m_Skinmap
- Public Attributes inherited from Obi.ObiMeshBasedActorBlueprint
Mesh inputMesh
Vector3 scale = Vector3.one
Quaternion rotation = Quaternion.identity
- Public Attributes inherited from Obi.ObiActorBlueprint
Vector3[] positions = null
Vector4[] restPositions = null
Quaternion[] orientations = null
Quaternion[] restOrientations = null
Vector3[] velocities = null
Vector3[] angularVelocities = null
float[] invMasses = null
float[] invRotationalMasses = null
int[] filters = null
Vector3[] principalRadii = null
Color[] colors = null
int[] points = null
int[] edges = null
int[] triangles = null
ObiDistanceConstraintsData distanceConstraintsData = null
ObiBendConstraintsData bendConstraintsData = null
ObiSkinConstraintsData skinConstraintsData = null
ObiTetherConstraintsData tetherConstraintsData = null
ObiStretchShearConstraintsData stretchShearConstraintsData = null
ObiBendTwistConstraintsData bendTwistConstraintsData = null
ObiShapeMatchingConstraintsData shapeMatchingConstraintsData = null
ObiAerodynamicConstraintsData aerodynamicConstraintsData = null
ObiChainConstraintsData chainConstraintsData = null
ObiVolumeConstraintsData volumeConstraintsData = null
List< ObiParticleGroup > groups = new List<ObiParticleGroup>()
override IEnumerator Initialize ()
override IEnumerator CreateDistanceConstraints ()
- Protected Member Functions inherited from Obi.ObiClothBlueprint
virtual IEnumerator CreateAerodynamicConstraints ()
virtual IEnumerator CreateBendingConstraints ()
virtual IEnumerator CreateVolumeConstraints ()
- Protected Member Functions inherited from Obi.ObiClothBlueprintBase
override void SwapWithFirstInactiveParticle (int index)
virtual IEnumerator GenerateDeformableTriangles ()
virtual IEnumerator CreateSimplices ()
virtual void CreateDefaultSkinmap (float radius, float falloff=1, uint maxInfluences=4, bool mapBonesToParticles=false)
- Protected Member Functions inherited from Obi.ObiActorBlueprint
void GenerateChecksum ()
int PooledParticles [get]
override bool usesTethers [get]
- Properties inherited from Obi.ObiClothBlueprint
- Properties inherited from Obi.ObiActorBlueprint
uint checksum [get]
virtual bool usesTethers [get]
bool edited [get, set]
bool empty [get]
Bounds bounds [get]
Additional Inherited Members
- Protected Attributes inherited from Obi.ObiClothBlueprint
GraphColoring colorizer
- Protected Attributes inherited from Obi.ObiClothBlueprintBase
ObiMesh m_Topology
ObiSkinMap m_Skinmap
- Protected Attributes inherited from Obi.ObiActorBlueprint
uint m_Checksum
bool m_Empty = true
bool m_Edited = false
int m_InitialActiveParticleCount = 0
Bounds _bounds = new Bounds()
- Events inherited from Obi.ObiActorBlueprint
BlueprintCallback OnBlueprintGenerate
Member Function Documentation
override IEnumerator Obi.ObiTearableClothBlueprint.Initialize ( )
protectedvirtual
Have a map for half-edge->constraint. Initially create all constraints and pre-cook them. Constraints at each side of the same edge, are in different batches.
Reimplemented from Obi.ObiClothBlueprint.
float [] Obi.ObiTearableClothBlueprint.tearResistance
Per-particle tear resistance.
Property Documentation
int Obi.ObiTearableClothBlueprint.PooledParticles
get
constraintHalfEdgeMap[half-edge index] = distance constraint index, or -1 if there's no constraint. Each initial constraint is the lower-index of each pair of half-edges. When a half-edge is split during tearing, one of the two half-edges gets its constraint updated and the other gets a new constraint.
