Obi.ObiClothBlueprintBase Class Reference
Inheritance diagram for Obi.ObiClothBlueprintBase:
Obi.ObiMeshBasedActorBlueprint Obi.ObiActorBlueprint Obi.IObiParticleCollection Obi.ObiClothBlueprint Obi.ObiSkinnedClothBlueprint Obi.ObiTearableClothBlueprint
int[] deformableTriangles = null
Vector2[] triangleUVs = null
Vector3[] restNormals = null
float[] areaContribution = null
const float DEFAULT_PARTICLE_MASS = 0.1f
ObiMesh topology => m_Topology
ObiSkinMap defaultSkinmap => m_Skinmap
- Public Attributes inherited from Obi.ObiMeshBasedActorBlueprint
Mesh inputMesh
Vector3 scale = Vector3.one
Quaternion rotation = Quaternion.identity
- Public Attributes inherited from Obi.ObiActorBlueprint
Vector3[] positions = null
Vector4[] restPositions = null
Quaternion[] orientations = null
Quaternion[] restOrientations = null
Vector3[] velocities = null
Vector3[] angularVelocities = null
float[] invMasses = null
float[] invRotationalMasses = null
int[] filters = null
Vector3[] principalRadii = null
Color[] colors = null
int[] points = null
int[] edges = null
int[] triangles = null
ObiDistanceConstraintsData distanceConstraintsData = null
ObiBendConstraintsData bendConstraintsData = null
ObiSkinConstraintsData skinConstraintsData = null
ObiTetherConstraintsData tetherConstraintsData = null
ObiStretchShearConstraintsData stretchShearConstraintsData = null
ObiBendTwistConstraintsData bendTwistConstraintsData = null
ObiShapeMatchingConstraintsData shapeMatchingConstraintsData = null
ObiAerodynamicConstraintsData aerodynamicConstraintsData = null
ObiChainConstraintsData chainConstraintsData = null
ObiVolumeConstraintsData volumeConstraintsData = null
List< ObiParticleGroup > groups = new List<ObiParticleGroup>()
override void SwapWithFirstInactiveParticle (int index)
virtual IEnumerator GenerateDeformableTriangles ()
virtual IEnumerator CreateSimplices ()
virtual void CreateDefaultSkinmap (float radius, float falloff=1, uint maxInfluences=4, bool mapBonesToParticles=false)
- Protected Member Functions inherited from Obi.ObiActorBlueprint
void GenerateChecksum ()
abstract IEnumerator Initialize ()
Protected Attributes
ObiMesh m_Topology
ObiSkinMap m_Skinmap
- Protected Attributes inherited from Obi.ObiActorBlueprint
uint m_Checksum
bool m_Empty = true
bool m_Edited = false
int m_InitialActiveParticleCount = 0
Bounds _bounds = new Bounds()
Additional Inherited Members
- Public Member Functions inherited from Obi.ObiActorBlueprint
delegate void BlueprintCallback (ObiActorBlueprint blueprint)
bool IsParticleActive (int index)
bool ActivateParticle (int index)
bool DeactivateParticle (int index)
void RecalculateBounds ()
IEnumerable< IObiConstraints > GetConstraints ()
int GetParticleRuntimeIndex (int blueprintIndex)
Vector3 GetParticlePosition (int index)
Quaternion GetParticleOrientation (int index)
Vector3 GetParticleRestPosition (int index)
Quaternion GetParticleRestOrientation (int index)
void GetParticleAnisotropy (int index, ref Vector4 b1, ref Vector4 b2, ref Vector4 b3)
float GetParticleMaxRadius (int index)
Color GetParticleColor (int index)
void GenerateImmediate ()
IEnumerator Generate ()
virtual void CommitBlueprintChanges ()
void Clear ()
ObiParticleGroup InsertNewParticleGroup (string name, int index, bool saveImmediately=true)
ObiParticleGroup AppendNewParticleGroup (string name, bool saveImmediately=true)
bool RemoveParticleGroupAt (int index, bool saveImmediately=true)
bool SetParticleGroupName (int index, string name, bool saveImmediately=true)
void ClearParticleGroups (bool registerUndo=true, bool saveImmediately=true)
virtual void RemoveSelectedParticles (ref bool[] selected, bool optimize=true)
void RestoreRemovedParticles ()
virtual void GenerateTethers (bool[] selected)
virtual void ClearTethers ()
- Properties inherited from Obi.ObiActorBlueprint
uint checksum [get]
virtual bool usesTethers [get]
bool edited [get, set]
bool empty [get]
Bounds bounds [get]
- Events inherited from Obi.ObiActorBlueprint
BlueprintCallback OnBlueprintGenerate
float [] Obi.ObiClothBlueprintBase.areaContribution = null
How much mesh surface area each particle represents.
int [] Obi.ObiClothBlueprintBase.deformableTriangles = null
Indices of deformable triangles (3 per triangle)
ObiMesh Obi.ObiClothBlueprintBase.m_Topology
protected
Topology generated from the input mesh.
Vector2 [] Obi.ObiClothBlueprintBase.triangleUVs = null
Deformable triangle UVS (3 per triangle).
