Obi.ObiActorBlueprint Class Referenceabstract
Inheritance diagram for Obi.ObiActorBlueprint:
Obi.IObiParticleCollection Obi.ObiBoneBlueprint Obi.ObiEmitterBlueprintBase Obi.ObiMeshBasedActorBlueprint Obi.ObiRopeBlueprintBase Obi.ObiFluidEmitterBlueprint Obi.ObiGranularEmitterBlueprint Obi.ObiClothBlueprintBase Obi.ObiSoftbodyBlueprintBase Obi.ObiRodBlueprint Obi.ObiRopeBlueprint Obi.ObiClothBlueprint Obi.ObiSoftbodySurfaceBlueprint Obi.ObiSkinnedClothBlueprint Obi.ObiTearableClothBlueprint
delegate void BlueprintCallback (ObiActorBlueprint blueprint)
bool IsParticleActive (int index)
bool ActivateParticle (int index)
bool DeactivateParticle (int index)
void RecalculateBounds ()
IEnumerable< IObiConstraints > GetConstraints ()
int GetParticleRuntimeIndex (int blueprintIndex)
Vector3 GetParticlePosition (int index)
Quaternion GetParticleOrientation (int index)
Vector3 GetParticleRestPosition (int index)
Quaternion GetParticleRestOrientation (int index)
void GetParticleAnisotropy (int index, ref Vector4 b1, ref Vector4 b2, ref Vector4 b3)
float GetParticleMaxRadius (int index)
Color GetParticleColor (int index)
void GenerateImmediate ()
IEnumerator Generate ()
virtual void CommitBlueprintChanges ()
void Clear ()
ObiParticleGroup InsertNewParticleGroup (string name, int index, bool saveImmediately=true)
ObiParticleGroup AppendNewParticleGroup (string name, bool saveImmediately=true)
bool RemoveParticleGroupAt (int index, bool saveImmediately=true)
bool SetParticleGroupName (int index, string name, bool saveImmediately=true)
void ClearParticleGroups (bool registerUndo=true, bool saveImmediately=true)
virtual void RemoveSelectedParticles (ref bool[] selected, bool optimize=true)
void RestoreRemovedParticles ()
virtual void GenerateTethers (bool[] selected)
virtual void ClearTethers ()
Vector3[] positions = null
Vector4[] restPositions = null
Quaternion[] orientations = null
Quaternion[] restOrientations = null
Vector3[] velocities = null
Vector3[] angularVelocities = null
float[] invMasses = null
float[] invRotationalMasses = null
int[] filters = null
Vector3[] principalRadii = null
Color[] colors = null
int[] points = null
int[] edges = null
int[] triangles = null
ObiDistanceConstraintsData distanceConstraintsData = null
ObiBendConstraintsData bendConstraintsData = null
ObiSkinConstraintsData skinConstraintsData = null
ObiTetherConstraintsData tetherConstraintsData = null
ObiStretchShearConstraintsData stretchShearConstraintsData = null
ObiBendTwistConstraintsData bendTwistConstraintsData = null
ObiShapeMatchingConstraintsData shapeMatchingConstraintsData = null
ObiAerodynamicConstraintsData aerodynamicConstraintsData = null
ObiChainConstraintsData chainConstraintsData = null
ObiVolumeConstraintsData volumeConstraintsData = null
List< ObiParticleGroup > groups = new List<ObiParticleGroup>()
virtual void SwapWithFirstInactiveParticle (int index)
void GenerateChecksum ()
abstract IEnumerator Initialize ()
Protected Attributes
uint m_Checksum
bool m_Empty = true
bool m_Edited = false
int m_InitialActiveParticleCount = 0
Bounds _bounds = new Bounds()
uint checksum [get]
virtual bool usesTethers [get]
bool edited [get, set]
bool empty [get]
Bounds bounds [get]
Events
BlueprintCallback OnBlueprintGenerate
Member Function Documentation
bool Obi.ObiActorBlueprint.ActivateParticle ( int  index)
Activates one particle. This operation preserves the relative order of all particles.
bool Obi.ObiActorBlueprint.DeactivateParticle ( int  index)
Deactivates one particle. This operation does not preserve the relative order of other particles, because the last active particle will swap positions with the particle being deactivated.
Vector3 [] Obi.ObiActorBlueprint.angularVelocities = null
Particle angular velocities.
Color [] Obi.ObiActorBlueprint.colors = null
Particle colors (not used by all actors, can be null)
ObiDistanceConstraintsData Obi.ObiActorBlueprint.distanceConstraintsData = null
Constraint components. Each constraint type contains a list of constraint batches.
int [] Obi.ObiActorBlueprint.filters = null
Particle filters
List<ObiParticleGroup> Obi.ObiActorBlueprint.groups = new List<ObiParticleGroup>()
Particle groups.
float [] Obi.ObiActorBlueprint.invMasses = null
Particle inverse masses
bool Obi.ObiActorBlueprint.m_Edited = false
protected
Whether there's been any modifications to blueprint data since generating it. This is used to tell whether it can be re-generated without data loss.
Quaternion [] Obi.ObiActorBlueprint.orientations = null
Particle orientations.
int [] Obi.ObiActorBlueprint.points = null
Simplices
Vector3 [] Obi.ObiActorBlueprint.positions = null
Particle components Particle positions.
Vector3 [] Obi.ObiActorBlueprint.principalRadii = null
Particle ellipsoid principal radii. These are the ellipsoid radius in each axis.
Quaternion [] Obi.ObiActorBlueprint.restOrientations = null
Particle rest orientations.
Vector4 [] Obi.ObiActorBlueprint.restPositions = null
Particle rest positions, used to filter collisions.
Vector3 [] Obi.ObiActorBlueprint.velocities = null
Particle velocities.
Property Documentation
uint Obi.ObiActorBlueprint.checksum
get
Checksum value generated from particle positions and orientations.
int Obi.ObiActorBlueprint.particleCount
get
Returns the amount of particles used by this blueprint.
bool Obi.ObiActorBlueprint.usesOrientedParticles
get
Returns whether this group uses oriented particles.
