| void | MapParticlesToVertices (Mesh mesh, IObiParticleCollection collection, Matrix4x4 verticesToWorld, Matrix4x4 worldToCollection, float radius=0.25f, float falloff=1, uint maxInfluences=4, bool influencedByBones=false, float particleInfluence=1, float[] particleInfuenceMap=null) |
| | Creates an influence map from particles to vertices: each vertex will be influenced by multiple particles. More...
void | MapBonesToParticles (Mesh mesh, ObiMesh particleMesh, Matrix4x4 verticesToWorld, Matrix4x4 worldToParticles, float falloff=1, uint maxInfluences=4) |
| void Obi.ObiSkinMap.MapParticlesToVertices |
Mesh |
mesh, |
IObiParticleCollection |
collection, |
Matrix4x4 |
verticesToWorld, |
Matrix4x4 |
worldToCollection, |
float |
radius = 0.25f, |
float |
falloff = 1, |
uint |
maxInfluences = 4, |
bool |
influencedByBones = false, |
float |
particleInfluence = 1, |
float[] |
particleInfuenceMap = null |
- Parameters
| mesh | the mesh to get vertices from. |
| collection | the particle collection. |
| verticesToWorld | transform from mesh space to world space. |
| worldToCollection | transform from world space to particle collection space. |
| radius | influence radius. |
| falloff | influence falloff. |
| maxInfluences | maximum amount of particle influences per vertex. |
for cloth, stores particle bind poses. For softbodies, stores both bone and particle bind poses.
for each particle, stores bone influences (cloth only)
| uint Obi.ObiSkinMap.checksum |
this skinmap's checksum, used to determine if the data it was generated from is no longer valid.
for each vertex, stores particle influences.
- Assets/Obi/Scripts/Common/DataStructures/SkinMap/ObiSkinMap.cs
