| areaContribution | Obi.ObiClothBlueprintBase | |
| CreateDefaultSkinmap(float radius, float falloff=1, uint maxInfluences=4, bool mapBonesToParticles=false) (defined in Obi.ObiClothBlueprintBase) | Obi.ObiClothBlueprintBase | protectedvirtual |
| CreateSimplices() (defined in Obi.ObiClothBlueprintBase) | Obi.ObiClothBlueprintBase | protectedvirtual |
| DEFAULT_PARTICLE_MASS (defined in Obi.ObiClothBlueprintBase) | Obi.ObiClothBlueprintBase | |
| defaultSkinmap (defined in Obi.ObiClothBlueprintBase) | Obi.ObiClothBlueprintBase | |
| deformableTriangles | Obi.ObiClothBlueprintBase | |
| GenerateDeformableTriangles() (defined in Obi.ObiClothBlueprintBase) | Obi.ObiClothBlueprintBase | protectedvirtual |
| Initialize() (defined in Obi.ObiActorBlueprint) | Obi.ObiActorBlueprint | protectedpure virtual |
| inputMesh | Obi.ObiMeshBasedActorBlueprint | |
| m_Skinmap (defined in Obi.ObiClothBlueprintBase) | Obi.ObiClothBlueprintBase | protected |
| m_Topology | Obi.ObiClothBlueprintBase | protected |
| restNormals (defined in Obi.ObiClothBlueprintBase) | Obi.ObiClothBlueprintBase | |
| rotation (defined in Obi.ObiMeshBasedActorBlueprint) | Obi.ObiMeshBasedActorBlueprint | |
| scale (defined in Obi.ObiMeshBasedActorBlueprint) | Obi.ObiMeshBasedActorBlueprint | |
| SwapWithFirstInactiveParticle(int index) (defined in Obi.ObiClothBlueprintBase) | Obi.ObiClothBlueprintBase | protectedvirtual |
| topology (defined in Obi.ObiClothBlueprintBase) | Obi.ObiClothBlueprintBase | |
| triangleUVs | Obi.ObiClothBlueprintBase | |
