Obi.ObiSoftbodySurfaceBlueprint Class Reference
Inheritance diagram for Obi.ObiSoftbodySurfaceBlueprint:
Obi.ObiSoftbodyBlueprintBase Obi.ObiMeshBasedActorBlueprint Obi.ObiActorBlueprint Obi.IObiParticleCollection
Classes
struct  ParticleToSurface
class  SimplexComparer
Public Types
enum  ParticleType {
  None = 0, Bone = 1 << 0, Volume = 1 << 1, Surface = 1 << 2,
  All = Bone | Volume | Surface
enum  VoxelConnectivity {
  None = 0, Faces = 1 << 0, Edges = 1 << 1, Vertices = 1 << 2,
  All = Faces | Edges | Vertices
enum  SurfaceSamplingMode { None, Vertices, Voxels }
enum  VolumeSamplingMode { None, Voxels }
enum  SamplingMode { Surface, Volume, Full }
override void CommitBlueprintChanges ()
- Public Member Functions inherited from Obi.ObiActorBlueprint
delegate void BlueprintCallback (ObiActorBlueprint blueprint)
bool IsParticleActive (int index)
bool ActivateParticle (int index)
bool DeactivateParticle (int index)
void RecalculateBounds ()
IEnumerable< IObiConstraints > GetConstraints ()
int GetParticleRuntimeIndex (int blueprintIndex)
Vector3 GetParticlePosition (int index)
Quaternion GetParticleOrientation (int index)
Vector3 GetParticleRestPosition (int index)
Quaternion GetParticleRestOrientation (int index)
void GetParticleAnisotropy (int index, ref Vector4 b1, ref Vector4 b2, ref Vector4 b3)
float GetParticleMaxRadius (int index)
Color GetParticleColor (int index)
void GenerateImmediate ()
IEnumerator Generate ()
void Clear ()
ObiParticleGroup InsertNewParticleGroup (string name, int index, bool saveImmediately=true)
ObiParticleGroup AppendNewParticleGroup (string name, bool saveImmediately=true)
bool RemoveParticleGroupAt (int index, bool saveImmediately=true)
bool SetParticleGroupName (int index, string name, bool saveImmediately=true)
void ClearParticleGroups (bool registerUndo=true, bool saveImmediately=true)
virtual void RemoveSelectedParticles (ref bool[] selected, bool optimize=true)
void RestoreRemovedParticles ()
virtual void GenerateTethers (bool[] selected)
virtual void ClearTethers ()
SurfaceSamplingMode surfaceSamplingMode = SurfaceSamplingMode.Voxels
int surfaceResolution = 16
VolumeSamplingMode volumeSamplingMode = VolumeSamplingMode.None
int volumeResolution = 16
GameObject skeleton
Transform rootBone
Quaternion boneRotation
float maxAnisotropy = 3
float smoothing = 0.25f
int shapeResolution = 48
Mesh generatedMesh = null
int[] vertexToParticle = null
List< ParticleType > particleType = null
List< Matrix4x4 > boneBindPoses = null
List< Vector2Int > bonePairs = null
const float DEFAULT_PARTICLE_MASS = 0.1f
- Public Attributes inherited from Obi.ObiSoftbodyBlueprintBase
ObiSkinMap defaultSkinmap => m_Skinmap
- Public Attributes inherited from Obi.ObiMeshBasedActorBlueprint
Mesh inputMesh
Vector3 scale = Vector3.one
Quaternion rotation = Quaternion.identity
- Public Attributes inherited from Obi.ObiActorBlueprint
Vector3[] positions = null
Vector4[] restPositions = null
Quaternion[] orientations = null
Quaternion[] restOrientations = null
Vector3[] velocities = null
Vector3[] angularVelocities = null
float[] invMasses = null
float[] invRotationalMasses = null
int[] filters = null
Vector3[] principalRadii = null
Color[] colors = null
int[] points = null
int[] edges = null
int[] triangles = null
ObiDistanceConstraintsData distanceConstraintsData = null
ObiBendConstraintsData bendConstraintsData = null
ObiSkinConstraintsData skinConstraintsData = null
ObiTetherConstraintsData tetherConstraintsData = null
ObiStretchShearConstraintsData stretchShearConstraintsData = null
ObiBendTwistConstraintsData bendTwistConstraintsData = null
ObiShapeMatchingConstraintsData shapeMatchingConstraintsData = null
ObiAerodynamicConstraintsData aerodynamicConstraintsData = null
ObiChainConstraintsData chainConstraintsData = null
ObiVolumeConstraintsData volumeConstraintsData = null
List< ObiParticleGroup > groups = new List<ObiParticleGroup>()
override IEnumerator Initialize ()
override void SwapWithFirstInactiveParticle (int index)
void ConnectToNeighborParticles (MeshVoxelizer voxelizer, int particle, List< Vector3 > particles, ParticleType allowedNeighborType, int x, int y, int z, Vector3Int[] neighborhood, float clusterSize, List< int > cluster)
IEnumerator CreateClustersFromVoxels (MeshVoxelizer voxelizer, List< Vector3 > particles, VoxelConnectivity connectivity, ParticleType allowedParticleType, ParticleType allowedNeighborType)
IEnumerator CreateClustersFromSkeleton (List< Vector3 > particles)
IEnumerator SurfaceMeshShapeMatchingConstraints (List< Vector3 > particles, int[] meshTriangles)
virtual IEnumerator CreateSimplices (List< Vector3 > particles, int[] meshTriangles)
virtual IEnumerator CreateShapeMatchingConstraints (List< Vector3 > particles)
void CreateDefaultSkinmap (float radius, float falloff=1, uint maxInfluences=4)
- Protected Member Functions inherited from Obi.ObiActorBlueprint
void GenerateChecksum ()
MeshVoxelizer surfaceVoxelizer [get, set]
MeshVoxelizer volumeVoxelizer [get, set]
MeshVoxelizer shapeVoxelizer [get, set]
- Properties inherited from Obi.ObiActorBlueprint
uint checksum [get]
virtual bool usesTethers [get]
bool edited [get, set]
bool empty [get]
Bounds bounds [get]
Additional Inherited Members
- Protected Attributes inherited from Obi.ObiSoftbodyBlueprintBase
ObiSkinMap m_Skinmap
- Protected Attributes inherited from Obi.ObiActorBlueprint
uint m_Checksum
bool m_Empty = true
bool m_Edited = false
int m_InitialActiveParticleCount = 0
Bounds _bounds = new Bounds()
- Events inherited from Obi.ObiActorBlueprint
BlueprintCallback OnBlueprintGenerate
float Obi.ObiSoftbodySurfaceBlueprint.maxAnisotropy = 3
Maximum particle anisotropy. High values will allow particles to deform to better fit their neighborhood.
Transform Obi.ObiSoftbodySurfaceBlueprint.rootBone
root bone used for skeleton particles.
