| boneBindPoses (defined in Obi.ObiSoftbodySurfaceBlueprint) | Obi.ObiSoftbodySurfaceBlueprint | |
| bonePairs (defined in Obi.ObiSoftbodySurfaceBlueprint) | Obi.ObiSoftbodySurfaceBlueprint | |
| boneRotation (defined in Obi.ObiSoftbodySurfaceBlueprint) | Obi.ObiSoftbodySurfaceBlueprint | |
| CommitBlueprintChanges() (defined in Obi.ObiSoftbodySurfaceBlueprint) | Obi.ObiSoftbodySurfaceBlueprint | virtual |
| ConnectToNeighborParticles(MeshVoxelizer voxelizer, int particle, List< Vector3 > particles, ParticleType allowedNeighborType, int x, int y, int z, Vector3Int[] neighborhood, float clusterSize, List< int > cluster) (defined in Obi.ObiSoftbodySurfaceBlueprint) | Obi.ObiSoftbodySurfaceBlueprint | protected |
| CreateClustersFromSkeleton(List< Vector3 > particles) (defined in Obi.ObiSoftbodySurfaceBlueprint) | Obi.ObiSoftbodySurfaceBlueprint | protected |
| CreateClustersFromVoxels(MeshVoxelizer voxelizer, List< Vector3 > particles, VoxelConnectivity connectivity, ParticleType allowedParticleType, ParticleType allowedNeighborType) (defined in Obi.ObiSoftbodySurfaceBlueprint) | Obi.ObiSoftbodySurfaceBlueprint | protected |
| CreateDefaultSkinmap(float radius, float falloff=1, uint maxInfluences=4) (defined in Obi.ObiSoftbodySurfaceBlueprint) | Obi.ObiSoftbodySurfaceBlueprint | protected |
| CreateShapeMatchingConstraints(List< Vector3 > particles) (defined in Obi.ObiSoftbodySurfaceBlueprint) | Obi.ObiSoftbodySurfaceBlueprint | protectedvirtual |
| CreateSimplices(List< Vector3 > particles, int[] meshTriangles) (defined in Obi.ObiSoftbodySurfaceBlueprint) | Obi.ObiSoftbodySurfaceBlueprint | protectedvirtual |
| DEFAULT_PARTICLE_MASS (defined in Obi.ObiSoftbodySurfaceBlueprint) | Obi.ObiSoftbodySurfaceBlueprint | |
| defaultSkinmap (defined in Obi.ObiSoftbodyBlueprintBase) | Obi.ObiSoftbodyBlueprintBase | |
| generatedMesh (defined in Obi.ObiSoftbodySurfaceBlueprint) | Obi.ObiSoftbodySurfaceBlueprint | |
| Initialize() (defined in Obi.ObiSoftbodySurfaceBlueprint) | Obi.ObiSoftbodySurfaceBlueprint | protectedvirtual |
| inputMesh | Obi.ObiMeshBasedActorBlueprint | |
| m_Skinmap (defined in Obi.ObiSoftbodyBlueprintBase) | Obi.ObiSoftbodyBlueprintBase | protected |
| maxAnisotropy | Obi.ObiSoftbodySurfaceBlueprint | |
| particleType (defined in Obi.ObiSoftbodySurfaceBlueprint) | Obi.ObiSoftbodySurfaceBlueprint | |
| ParticleType enum name (defined in Obi.ObiSoftbodySurfaceBlueprint) | Obi.ObiSoftbodySurfaceBlueprint | |
| rootBone | Obi.ObiSoftbodySurfaceBlueprint | |
| rotation (defined in Obi.ObiMeshBasedActorBlueprint) | Obi.ObiMeshBasedActorBlueprint | |
| SamplingMode enum name (defined in Obi.ObiSoftbodySurfaceBlueprint) | Obi.ObiSoftbodySurfaceBlueprint | |
| scale (defined in Obi.ObiMeshBasedActorBlueprint) | Obi.ObiMeshBasedActorBlueprint | |
| shapeResolution (defined in Obi.ObiSoftbodySurfaceBlueprint) | Obi.ObiSoftbodySurfaceBlueprint | |
| shapeVoxelizer (defined in Obi.ObiSoftbodySurfaceBlueprint) | Obi.ObiSoftbodySurfaceBlueprint | |
| skeleton (defined in Obi.ObiSoftbodySurfaceBlueprint) | Obi.ObiSoftbodySurfaceBlueprint | |
| smoothing (defined in Obi.ObiSoftbodySurfaceBlueprint) | Obi.ObiSoftbodySurfaceBlueprint | |
| SurfaceMeshShapeMatchingConstraints(List< Vector3 > particles, int[] meshTriangles) (defined in Obi.ObiSoftbodySurfaceBlueprint) | Obi.ObiSoftbodySurfaceBlueprint | protected |
| surfaceResolution (defined in Obi.ObiSoftbodySurfaceBlueprint) | Obi.ObiSoftbodySurfaceBlueprint | |
| SurfaceSamplingMode enum name (defined in Obi.ObiSoftbodySurfaceBlueprint) | Obi.ObiSoftbodySurfaceBlueprint | |
| surfaceSamplingMode (defined in Obi.ObiSoftbodySurfaceBlueprint) | Obi.ObiSoftbodySurfaceBlueprint | |
| surfaceVoxelizer (defined in Obi.ObiSoftbodySurfaceBlueprint) | Obi.ObiSoftbodySurfaceBlueprint | |
| SwapWithFirstInactiveParticle(int index) (defined in Obi.ObiSoftbodySurfaceBlueprint) | Obi.ObiSoftbodySurfaceBlueprint | protectedvirtual |
| vertexToParticle (defined in Obi.ObiSoftbodySurfaceBlueprint) | Obi.ObiSoftbodySurfaceBlueprint | |
| volumeResolution (defined in Obi.ObiSoftbodySurfaceBlueprint) | Obi.ObiSoftbodySurfaceBlueprint | |
| volumeSamplingMode (defined in Obi.ObiSoftbodySurfaceBlueprint) | Obi.ObiSoftbodySurfaceBlueprint | |
| VolumeSamplingMode enum name (defined in Obi.ObiSoftbodySurfaceBlueprint) | Obi.ObiSoftbodySurfaceBlueprint | |
| volumeVoxelizer (defined in Obi.ObiSoftbodySurfaceBlueprint) | Obi.ObiSoftbodySurfaceBlueprint | |
| VoxelConnectivity enum name (defined in Obi.ObiSoftbodySurfaceBlueprint) | Obi.ObiSoftbodySurfaceBlueprint | |
