Obi.ObiPlant Class Reference
Inheritance diagram for Obi.ObiPlant:
Obi.ObiActor Obi.ObiActor Obi.IObiParticleCollection Obi.IObiParticleCollection
Classes
class  Meristem
struct  Node
class  SurfacePoint
Public Types
enum  LeafType {
  Square, Cross, Diamond, DiamondCross,
  Long, Custom
void Start ()
int AddGenerator (ObiPlantGenerator.GeneratorType type, string name, int parent)
void RemoveGenerator (int index)
bool IsGrowing ()
int GetGeneratorLevel (ObiPlantGenerator generator)
void InstantGrow ()
void GenerateTrunkGeometry ()
void GenerateTrunkCurves ()
- Public Member Functions inherited from Obi.ObiActor
delegate void ActorCallback (ObiActor actor)
delegate void ActorStepCallback (ObiActor actor, float simulatedTime, float substepTime)
delegate void ActorBlueprintCallback (ObiActor actor, ObiActorBlueprint blueprint)
void AddToSolver ()
 Adds this actor to its solver, if any. Automatically called by ObiSolver. More...
void RemoveFromSolver ()
 Remove this actor from its solver, if any. Automatically called by ObiSolver. More...
virtual void ProvideDeformableTriangles (ObiNativeIntList deformableTriangles, ObiNativeVector2List deformableUVs)
virtual void ProvideDeformableEdges (ObiNativeIntList deformableEdges)
virtual int GetDeformableEdgeCount ()
virtual bool CopyParticle (int actorSourceIndex, int actorDestIndex)
 Copies all data (position, velocity, phase, etc) from one particle to another one. More...
void TeleportParticle (int actorIndex, Vector3 position)
 Teleports one actor particle to a certain position in solver space. More...
virtual Matrix4x4 Teleport (Vector3 position, Quaternion rotation)
 Teleports the entire actor to a new location / orientation. More...
virtual bool ActivateParticle ()
 Activates one particle. More...
virtual bool DeactivateParticle (int actorIndex)
 Deactivates one particle. More...
virtual bool IsParticleActive (int actorIndex)
 Returns whether a given particle is active. More...
virtual void SetSelfCollisions (bool selfCollisions)
 Updates particle phases in the solver at runtime, including or removing the self-collision flag. More...
virtual void SetOneSided (bool oneSided)
 Updates particle phases in the solver at runtime, including or removing the one-sided flag. More...
void SetSimplicesDirty ()
 Marks simplices dirty. More...
void SetConstraintsDirty (Oni.ConstraintType constraintType)
 Marks a given constraint type as dirty. More...
void SetRenderingDirty (Oni.RenderingSystemType rendererType)
 Marks rendering dirty. More...
 Returns the data representation of constraints of a given type being simulated by this solver. More...
virtual void UpdateParticleProperties ()
 Call when some particle properties have been modified and need updating. More...
int GetParticleRuntimeIndex (int actorIndex)
 Returns the index of this particle in the solver arrays. More...
Vector3 GetParticlePosition (int solverIndex)
 Given a solver particle index, returns the position of that particle in world space. More...
Quaternion GetParticleOrientation (int solverIndex)
 Given a solver particle index, returns the orientation of that particle in world space. More...
Vector3 GetParticleRestPosition (int solverIndex)
 Given a solver particle index, returns the rest position of that particle. More...
Quaternion GetParticleRestOrientation (int solverIndex)
 Given a solver particle index, returns the rest orientation of that particle. More...
void GetParticleAnisotropy (int solverIndex, ref Vector4 b1, ref Vector4 b2, ref Vector4 b3)
 Given a solver particle index, returns the anisotropic frame of that particle in world space. More...
float GetParticleMaxRadius (int solverIndex)
 Given a solver particle index, returns the maximum world space radius of that particle, in any axis. More...
Color GetParticleColor (int solverIndex)
 Given a solver particle index, returns the color of that particle. More...
void SetFilterCategory (int newCategory)
 Sets a given category value for all particles in the actor. More...
void SetFilterMask (int newMask)
 Sets a given mask value for all particles in the actor. More...
void SetMass (float mass)
 Sets the inverse mass of each particle so that the total actor mass matches the one passed by parameter. More...
float GetMass (out Vector3 com)
 Returns the actor's mass (sum of all particle masses), and the position of its center of mass. More...
void AddForce (Vector3 force, ForceMode forceMode)
 Adds an external force to all particles in the actor. More...
void AddTorque (Vector3 force, ForceMode forceMode)
 Adds a torque to the actor. More...
void ResetParticles ()
 Resets the position and velocity of all particles, to the values stored in the blueprint. More...
bool SaveStateToBlueprint (ObiActorBlueprint bp)
void ClearState ()
virtual void SimulationStart (float timeToSimulate, float substepTime)
virtual void SimulationEnd (float simulatedTime, float substepTime)
virtual void RequestReadback ()
virtual void Interpolate (float simulatedTime, float substepTime)
virtual void OnSolverVisibilityChanged (bool visible)
const float DEFAULT_PARTICLE_ROTATIONAL_MASS = 0.005f
const float MAX_YOUNG_MODULUS = 25000000000
const float MIN_YOUNG_MODULUS = 10
int pooledParticles = 250
bool instantGrowth = true
int seed = 0
List< ObiPlantGenerator > generators = new List<ObiPlantGenerator>()
List< Meristem > meristems
int[] parentIndices
float[] parentOffsets
int[] levels
SurfacePoint[] closestSurfaces
- Public Attributes inherited from Obi.ObiActor
ObiNativeIntList solverIndices
 Index of each one of the actor's particles in the solver. More...
List< int >[] solverBatchOffsets
 For each of the actor's constraint types, offset of every batch in the solver. More...
int groupID = 0
override void OnEnable ()
override void OnDisable ()
void LazyMeshInitialization ()
void UpdateMesh ()
- Protected Member Functions inherited from Obi.ObiActor
virtual void Awake ()
virtual void OnDestroy ()
virtual void OnValidate ()
void SetSolver (ObiSolver newSolver)
 Forcibly changes the solver in charge of this actor More...
void SetMassScale (float scale)
 Sets the mass of all particles in the actor to their blueprint values, multiplied by a scale factor. More...
virtual void OnBlueprintRegenerate (ObiActorBlueprint blueprint)
void UpdateCollisionMaterials ()
virtual void SwapWithFirstInactiveParticle (int actorIndex)
void StoreState ()
int UsedParticles [get]
override ObiActorBlueprint sourceBlueprint [get]
- Properties inherited from Obi.ObiActor
int deformableEdgesOffset [get, set]
ObiSolver solver [get]
 The solver in charge of simulating this actor. More...
bool isLoaded [get]
 True if the actor blueprint has been loaded into a solver. If true, it guarantees actor.solver, actor.solverIndices and actor.solverBatchOffsets won't be null. More...
ObiCollisionMaterial collisionMaterial [get, set]
 The collision material being used by this actor. More...
virtual bool surfaceCollisions [get, set]
 Whether to use simplices (triangles, edges) for contact generation. More...
float massScale [get, set]
 Scale applied to this actor's particle masses. More...
 Amount of particles allocated by this actor. More...
 Amount of particles in use by this actor. More...
 Whether this actors makes use of particle orientations or not. More...
virtual bool usesAnisotropicParticles [get]
 If true, it means particles may not be completely spherical, but ellipsoidal. More...
Matrix4x4 actorLocalToSolverMatrix [get]
 Matrix that transforms from the actor's local space to the solver's local space. More...
Matrix4x4 actorSolverToLocalMatrix [get]
 Matrix that transforms from the solver's local space to the actor's local space. More...
abstract ObiActorBlueprint sourceBlueprint [get]
 Reference to the blueprint asset used by this actor. More...
ObiActorBlueprint sharedBlueprint [get]
 Reference to the blueprint in use by this actor. More...
ObiActorBlueprint blueprint [get]
 Returns a unique instance of this actor's sourceBlueprint. More...
Additional Inherited Members
- Protected Attributes inherited from Obi.ObiActor
ObiSolver m_Solver
bool m_Loaded = false
ObiCollisionMaterial m_CollisionMaterial
bool m_SurfaceCollisions = false
float m_MassScale = 1
- Events inherited from Obi.ObiActor
ActorBlueprintCallback OnBlueprintLoaded
 Called when the actor blueprint has been loaded into the solver. More...
ActorBlueprintCallback OnBlueprintUnloaded
 Called when the actor blueprint has been unloaded from the solver. More...
ActorBlueprintCallback OnBlueprintRegenerated
 Called when the blueprint currently in use has been re-generated. This will always be preceded by a call to OnBlueprintUnloaded and OnBlueprintLoaded. More...
ActorStepCallback OnSimulationStart
 Called before simulation starts. More...
ActorStepCallback OnSimulationEnd
 Called after simulation ends. More...
ActorCallback OnRequestReadback
 You can use this callback to issue GPU->CPU readbacks. More...
ActorStepCallback OnInterpolate
 Called at the end of each frame, after interpolation but before rendering. More...
Member Function Documentation
int Obi.ObiPlant.AddGenerator ( ObiPlantGenerator.GeneratorType  type,
string  name,
int  parent
Generates the particle based physical representation of the rope. This is the initialization method for the rope object and should not be called directly once the object has been created.
void Obi.ObiPlant.GenerateTrunkGeometry ( )
Clears the plant mesh, and then fills it with trunk geometry by first calculating curves and then generating vertices/triangles around them.
float [] Obi.ObiPlant.parentOffsets
normalized offset from the parent particle's center
The documentation for this class was generated from the following files:
