This is the complete list of members for Obi.ObiPlant, including all inherited members.
| AddGenerator(ObiPlantGenerator.GeneratorType type, string name, int parent) | Obi.ObiPlant | |
| closestSurfaces (defined in Obi.ObiPlant) | Obi.ObiPlant | |
| DEFAULT_PARTICLE_ROTATIONAL_MASS (defined in Obi.ObiPlant) | Obi.ObiPlant | |
| GenerateTrunkCurves() (defined in Obi.ObiPlant) | Obi.ObiPlant | |
| GenerateTrunkGeometry() | Obi.ObiPlant | |
| generators (defined in Obi.ObiPlant) | Obi.ObiPlant | |
| GetDeformableEdgeCount() (defined in Obi.ObiActor) | Obi.ObiActor | virtual |
| GetGeneratorLevel(ObiPlantGenerator generator) (defined in Obi.ObiPlant) | Obi.ObiPlant | |
| InstantGrow() (defined in Obi.ObiPlant) | Obi.ObiPlant | |
| instantGrowth (defined in Obi.ObiPlant) | Obi.ObiPlant | |
| IsGrowing() (defined in Obi.ObiPlant) | Obi.ObiPlant | |
| LazyMeshInitialization() (defined in Obi.ObiPlant) | Obi.ObiPlant | protected |
| LeafType enum name (defined in Obi.ObiPlant) | Obi.ObiPlant | |
| levels (defined in Obi.ObiPlant) | Obi.ObiPlant | |
| MAX_YOUNG_MODULUS (defined in Obi.ObiPlant) | Obi.ObiPlant | |
| meristems (defined in Obi.ObiPlant) | Obi.ObiPlant | |
| MIN_YOUNG_MODULUS (defined in Obi.ObiPlant) | Obi.ObiPlant | |
| OnDisable() (defined in Obi.ObiPlant) | Obi.ObiPlant | protectedvirtual |
| OnEnable() (defined in Obi.ObiPlant) | Obi.ObiPlant | protectedvirtual |
| OnValidate() (defined in Obi.ObiActor) | Obi.ObiActor | protectedvirtual |
| parentIndices (defined in Obi.ObiPlant) | Obi.ObiPlant | |
| parentOffsets | Obi.ObiPlant | |
| pooledParticles (defined in Obi.ObiPlant) | Obi.ObiPlant | |
| ProvideDeformableEdges(ObiNativeIntList deformableEdges) (defined in Obi.ObiActor) | Obi.ObiActor | virtual |
| ProvideDeformableTriangles(ObiNativeIntList deformableTriangles, ObiNativeVector2List deformableUVs) (defined in Obi.ObiActor) | Obi.ObiActor | virtual |
| RemoveGenerator(int index) (defined in Obi.ObiPlant) | Obi.ObiPlant | |
| RequestReadback() (defined in Obi.ObiActor) | Obi.ObiActor | virtual |
| seed (defined in Obi.ObiPlant) | Obi.ObiPlant | |
| SimulationEnd(float simulatedTime, float substepTime) (defined in Obi.ObiActor) | Obi.ObiActor | virtual |
| SimulationStart(float timeToSimulate, float substepTime) (defined in Obi.ObiActor) | Obi.ObiActor | virtual |
| sourceBlueprint (defined in Obi.ObiPlant) | Obi.ObiPlant | |
| Start() (defined in Obi.ObiPlant) | Obi.ObiPlant | |
| UpdateMesh() (defined in Obi.ObiPlant) | Obi.ObiPlant | protected |
| UsedParticles (defined in Obi.ObiPlant) | Obi.ObiPlant | |
| usesOrientedParticles | Obi.ObiActor |
