Obi.ObiPlantGenerator Class Reference
Public Types
enum  GeneratorType { Trunk, Branch, Leaves }
 ObiPlantGenerator (GeneratorType type, string name, int id, int parent)
void InitRNGState (int seed)
void StoreRNGState ()
void LoadRNGState ()
void GenerateNodes (ObiPlantGenerator parent)
ObiPlant.Node PlaceNode (ObiPathFrame section, Vector3 gravity, float angle, float normPos, int generatorId)
ObiPlant.Node PlaceLocalNode (float radius, float angle, float normPos, int generatorId)
GeneratorType type = GeneratorType.Trunk
string name = "Generator"
int parent = -1
int id = 0
AnimationCurve shape = AnimationCurve.Constant(0,1,1)
float length = 5
float thickness = 0.2f
float resolution = 8
float growthRate = 1
float randomness = 0.1f
Color color = Color.white
float phototropism = 0.1f
float lightGrowthBoost = 1.5f
float thigmotropism = 0.1f
float massMultiplier = 1
float rigidness = 10
float frequency = 0.25f
int multiplicity = 1
float branchingProbability = 0.1f
AnimationCurve branchingCurve = AnimationCurve.Constant(0,1,1)
float spread = 0
float twirl = 0
Vector2 growthAngle = Vector2.zero
Vector2 horizontalAlign = Vector2.zero
float verticalRandomness = 0.2f
Vector2 distanceFromTrunk = Vector2.zero
ObiPlant.LeafType leafType = ObiPlant.LeafType.Square
Mesh customLeaf
Vector3 leafScale = Vector3.one
Vector2 sizeRange = new Vector2(1,2.5f)
float trunkScale = 0.5f
uint smoothness = 0
float curvatureDetail = 1
float perimeterDetail = 40
float thicknessScale = 1
Vector2 uvScale = new Vector2(1,1)
ObiList< ObiPlant.Node > nodes = new ObiList<ObiPlant.Node>()
GeneratorType Type [get]
float MaxParticleLength [get]
Detailed Description
Struct that holds data for a branch level: level, growth rate, etc.
Member Function Documentation
void Obi.ObiPlantGenerator.GenerateNodes ( ObiPlantGenerator  parent)
Pregenerate nodes:
ObiList<ObiPlant.Node> Obi.ObiPlantGenerator.nodes = new ObiList<ObiPlant.Node>()
List of nodes generated
float Obi.ObiPlantGenerator.resolution = 8
amount of particles per length unit.
