| branchingCurve (defined in Obi.ObiPlantGenerator) | Obi.ObiPlantGenerator | |
| branchingProbability (defined in Obi.ObiPlantGenerator) | Obi.ObiPlantGenerator | |
| color (defined in Obi.ObiPlantGenerator) | Obi.ObiPlantGenerator | |
| curvatureDetail (defined in Obi.ObiPlantGenerator) | Obi.ObiPlantGenerator | |
| customLeaf (defined in Obi.ObiPlantGenerator) | Obi.ObiPlantGenerator | |
| distanceFromTrunk (defined in Obi.ObiPlantGenerator) | Obi.ObiPlantGenerator | |
| frequency (defined in Obi.ObiPlantGenerator) | Obi.ObiPlantGenerator | |
| GenerateNodes(ObiPlantGenerator parent) | Obi.ObiPlantGenerator | |
| GeneratorType enum name (defined in Obi.ObiPlantGenerator) | Obi.ObiPlantGenerator | |
| growthAngle (defined in Obi.ObiPlantGenerator) | Obi.ObiPlantGenerator | |
| growthRate (defined in Obi.ObiPlantGenerator) | Obi.ObiPlantGenerator | |
| horizontalAlign (defined in Obi.ObiPlantGenerator) | Obi.ObiPlantGenerator | |
| id (defined in Obi.ObiPlantGenerator) | Obi.ObiPlantGenerator | |
| InitRNGState(int seed) (defined in Obi.ObiPlantGenerator) | Obi.ObiPlantGenerator | |
| leafScale (defined in Obi.ObiPlantGenerator) | Obi.ObiPlantGenerator | |
| leafType (defined in Obi.ObiPlantGenerator) | Obi.ObiPlantGenerator | |
| length (defined in Obi.ObiPlantGenerator) | Obi.ObiPlantGenerator | |
| lightGrowthBoost (defined in Obi.ObiPlantGenerator) | Obi.ObiPlantGenerator | |
| LoadRNGState() (defined in Obi.ObiPlantGenerator) | Obi.ObiPlantGenerator | |
| massMultiplier (defined in Obi.ObiPlantGenerator) | Obi.ObiPlantGenerator | |
| MaxParticleLength (defined in Obi.ObiPlantGenerator) | Obi.ObiPlantGenerator | |
| multiplicity (defined in Obi.ObiPlantGenerator) | Obi.ObiPlantGenerator | |
| nodes | Obi.ObiPlantGenerator | |
| ObiPlantGenerator(GeneratorType type, string name, int id, int parent) (defined in Obi.ObiPlantGenerator) | Obi.ObiPlantGenerator | |
| parent (defined in Obi.ObiPlantGenerator) | Obi.ObiPlantGenerator | |
| perimeterDetail (defined in Obi.ObiPlantGenerator) | Obi.ObiPlantGenerator | |
| phototropism (defined in Obi.ObiPlantGenerator) | Obi.ObiPlantGenerator | |
| PlaceLocalNode(float radius, float angle, float normPos, int generatorId) (defined in Obi.ObiPlantGenerator) | Obi.ObiPlantGenerator | |
| PlaceNode(ObiPathFrame section, Vector3 gravity, float angle, float normPos, int generatorId) (defined in Obi.ObiPlantGenerator) | Obi.ObiPlantGenerator | |
| randomness (defined in Obi.ObiPlantGenerator) | Obi.ObiPlantGenerator | |
| resolution | Obi.ObiPlantGenerator | |
| rigidness (defined in Obi.ObiPlantGenerator) | Obi.ObiPlantGenerator | |
| shape (defined in Obi.ObiPlantGenerator) | Obi.ObiPlantGenerator | |
| sizeRange (defined in Obi.ObiPlantGenerator) | Obi.ObiPlantGenerator | |
| smoothness (defined in Obi.ObiPlantGenerator) | Obi.ObiPlantGenerator | |
| spread (defined in Obi.ObiPlantGenerator) | Obi.ObiPlantGenerator | |
| StoreRNGState() (defined in Obi.ObiPlantGenerator) | Obi.ObiPlantGenerator | |
| thickness (defined in Obi.ObiPlantGenerator) | Obi.ObiPlantGenerator | |
| thicknessScale (defined in Obi.ObiPlantGenerator) | Obi.ObiPlantGenerator | |
| thigmotropism (defined in Obi.ObiPlantGenerator) | Obi.ObiPlantGenerator | |
| trunkScale (defined in Obi.ObiPlantGenerator) | Obi.ObiPlantGenerator | |
| twirl (defined in Obi.ObiPlantGenerator) | Obi.ObiPlantGenerator | |
| type (defined in Obi.ObiPlantGenerator) | Obi.ObiPlantGenerator | |
| uvScale (defined in Obi.ObiPlantGenerator) | Obi.ObiPlantGenerator | |
| verticalRandomness (defined in Obi.ObiPlantGenerator) | Obi.ObiPlantGenerator | |
