| ObiVolumeConstraintsBatch (ObiVolumeConstraintsData constraints=null) |
void | AddConstraint (int[] triangles, float restVolume) |
override void | Clear () |
override void | GetParticlesInvolved (int index, List< int > particles) |
override void | Merge (ObiActor actor, IObiConstraintsBatch other) |
override void | AddToSolver (ObiSolver solver) |
override void | RemoveFromSolver (ObiSolver solver) |
void | SetParameters (float compliance, float pressure) |
bool | IsConstraintActive (int index) |
bool | ActivateConstraint (int constraintIndex) |
bool | DeactivateConstraint (int constraintIndex) |
void | DeactivateAllConstraints () |
void | ActivateAllConstraints () |
void | RemoveConstraint (int constraintIndex) |
void | ParticlesSwapped (int index, int newIndex) |
IVolumeConstraintsBatchImpl | m_BatchImpl |
List< int > | m_IDs = new List<int>() |
int | m_ConstraintCount = 0 |
int | m_ActiveConstraintCount = 0 |
int | m_InitialActiveConstraintCount = 0 |
override Oni.ConstraintType | constraintType [get] |
override IConstraintsBatchImpl | implementation [get] |
int | constraintCount [get] |
int | activeConstraintCount [get, set] |
virtual int | initialActiveConstraintCount [get, set] |
abstract Oni.ConstraintType | constraintType [get] |
abstract IConstraintsBatchImpl | implementation [get] |
index of the first triangle for each constraint (exclusive prefix sum).
number of triangles for each constraint.
2 floats per constraint: pressure and stiffness.
rest volume for each constraint.
- Assets/Obi/Scripts/Common/Blueprints/Constraints/Batches/ObiVolumeConstraintsBatch.cs
