virtual void | Merge (ObiActor actor, IObiConstraintsBatch other) |
abstract void | GetParticlesInvolved (int index, List< int > particles) |
virtual void | AddToSolver (ObiSolver solver) |
virtual void | RemoveFromSolver (ObiSolver solver) |
virtual void | Clear () |
bool | IsConstraintActive (int index) |
bool | ActivateConstraint (int constraintIndex) |
bool | DeactivateConstraint (int constraintIndex) |
void | DeactivateAllConstraints () |
void | ActivateAllConstraints () |
void | RemoveConstraint (int constraintIndex) |
void | ParticlesSwapped (int index, int newIndex) |
List< int > | m_IDs = new List<int>() |
int | m_ConstraintCount = 0 |
int | m_ActiveConstraintCount = 0 |
int | m_InitialActiveConstraintCount = 0 |
int | constraintCount [get] |
int | activeConstraintCount [get, set] |
virtual int | initialActiveConstraintCount [get, set] |
abstract Oni.ConstraintType | constraintType [get] |
abstract IConstraintsBatchImpl | implementation [get] |
| int Obi.ObiConstraintsBatch.GetConstraintIndex |
int |
constraintId | ) |
Given the id of a constraint, return its index in the constraint data arrays. Will return -1 if the constraint does not exist.
| void Obi.ObiConstraintsBatch.RegisterConstraint |
protected |
Registers a new constraint. Call this before adding a new contraint to the batch, so that the constraint is given an ID and the amount of constraints increased.
| List<int> Obi.ObiConstraintsBatch.m_IDToIndex = new List<int>() |
protected |
maps from constraint ID to constraint index. When activating/deactivating constraints, their order changes. That makes this map necessary. All active constraints are at the beginning of the constraint arrays, in the 0, activeConstraintCount index range.
particle indices, amount of them per constraint can be variable.
- Assets/Obi/Scripts/Common/Blueprints/Constraints/Batches/ObiConstraintsBatch.cs
