| areaContribution | Obi.ObiClothBlueprintBase | |
| ClearTethers() (defined in Obi.ObiClothBlueprint) | Obi.ObiClothBlueprint | virtual |
| colorizer (defined in Obi.ObiClothBlueprint) | Obi.ObiClothBlueprint | protected |
| CommitBlueprintChanges() (defined in Obi.ObiSkinnedClothBlueprint) | Obi.ObiSkinnedClothBlueprint | virtual |
| CreateAerodynamicConstraints() (defined in Obi.ObiClothBlueprint) | Obi.ObiClothBlueprint | protectedvirtual |
| CreateBendingConstraints() (defined in Obi.ObiClothBlueprint) | Obi.ObiClothBlueprint | protectedvirtual |
| CreateDefaultSkinmap(float radius, float falloff=1, uint maxInfluences=4, bool mapBonesToParticles=false) (defined in Obi.ObiClothBlueprintBase) | Obi.ObiClothBlueprintBase | protectedvirtual |
| CreateDistanceConstraints() (defined in Obi.ObiClothBlueprint) | Obi.ObiClothBlueprint | protectedvirtual |
| CreateSimplices() (defined in Obi.ObiClothBlueprintBase) | Obi.ObiClothBlueprintBase | protectedvirtual |
| CreateSkinConstraints() (defined in Obi.ObiSkinnedClothBlueprint) | Obi.ObiSkinnedClothBlueprint | protected |
| CreateVolumeConstraints() (defined in Obi.ObiClothBlueprint) | Obi.ObiClothBlueprint | protectedvirtual |
| DEFAULT_PARTICLE_MASS (defined in Obi.ObiClothBlueprintBase) | Obi.ObiClothBlueprintBase | |
| defaultSkinmap (defined in Obi.ObiClothBlueprintBase) | Obi.ObiClothBlueprintBase | |
| deformableTriangles | Obi.ObiClothBlueprintBase | |
| GenerateDeformableTriangles() (defined in Obi.ObiClothBlueprintBase) | Obi.ObiClothBlueprintBase | protectedvirtual |
| GenerateTethers(bool[] selected) | Obi.ObiClothBlueprint | virtual |
| Initialize() (defined in Obi.ObiSkinnedClothBlueprint) | Obi.ObiSkinnedClothBlueprint | protectedvirtual |
| inputMesh | Obi.ObiMeshBasedActorBlueprint | |
| m_Skinmap (defined in Obi.ObiClothBlueprintBase) | Obi.ObiClothBlueprintBase | protected |
| m_Topology | Obi.ObiClothBlueprintBase | protected |
| minimumParticleSize (defined in Obi.ObiClothBlueprint) | Obi.ObiClothBlueprint | |
| RemoveSelectedParticles(ref bool[] selected, bool optimize=true) (defined in Obi.ObiSkinnedClothBlueprint) | Obi.ObiSkinnedClothBlueprint | virtual |
| restNormals (defined in Obi.ObiClothBlueprintBase) | Obi.ObiClothBlueprintBase | |
| rotation (defined in Obi.ObiMeshBasedActorBlueprint) | Obi.ObiMeshBasedActorBlueprint | |
| scale (defined in Obi.ObiMeshBasedActorBlueprint) | Obi.ObiMeshBasedActorBlueprint | |
| SwapWithFirstInactiveParticle(int index) (defined in Obi.ObiClothBlueprintBase) | Obi.ObiClothBlueprintBase | protectedvirtual |
| topology (defined in Obi.ObiClothBlueprintBase) | Obi.ObiClothBlueprintBase | |
| triangleUVs | Obi.ObiClothBlueprintBase | |
| usesTethers (defined in Obi.ObiSkinnedClothBlueprint) | Obi.ObiSkinnedClothBlueprint | |
| vertexWeldDistance (defined in Obi.ObiClothBlueprint) | Obi.ObiClothBlueprint | |
