Obi.ObiPinholeConstraintsBatch Class Reference
Inheritance diagram for Obi.ObiPinholeConstraintsBatch:
Obi.ObiConstraintsBatch Obi.IObiConstraintsBatch
Classes
struct  PinholeEdge
 ObiPinholeConstraintsBatch (ObiPinholeConstraintsData constraints=null)
void AddConstraint (PinholeEdge edge, PinholeEdge firstEdge, PinholeEdge lastEdge, ObiActor actor, ObiColliderBase body, Vector3 offset, float compliance, float friction, float motorSpeed, float motorForce, bool clampAtEnds)
override void Clear ()
override void GetParticlesInvolved (int index, List< int > particles)
override void Merge (ObiActor actor, IObiConstraintsBatch other)
override void AddToSolver (ObiSolver solver)
override void RemoveFromSolver (ObiSolver solver)
- Public Member Functions inherited from Obi.ObiConstraintsBatch
int GetConstraintIndex (int constraintId)
bool IsConstraintActive (int index)
bool ActivateConstraint (int constraintIndex)
bool DeactivateConstraint (int constraintIndex)
void DeactivateAllConstraints ()
void ActivateAllConstraints ()
void RemoveConstraint (int constraintIndex)
void ParticlesSwapped (int index, int newIndex)
List< ObiColliderHandle > pinBodies = new List<ObiColliderHandle>()
 for each constraint, handle of the pinned collider. More...
List< ObiActor > pinActors = new List<ObiActor>()
 for each constraint, reference to the actor pinned. More...
ObiNativeIntList colliderIndices = new ObiNativeIntList()
 index of the pinned collider in the collider world. More...
ObiNativeVector4List offsets = new ObiNativeVector4List()
 Pinhole position expressed in the attachment's local space. More...
ObiNativeFloatList edgeMus = new ObiNativeFloatList()
ObiNativeIntList edgeRanges = new ObiNativeIntList()
 Edge range as 2 ints (first edge, last edge) for each constraint. More...
ObiNativeFloatList edgeRangeMus = new ObiNativeFloatList()
 Min/max cooridnate in each of the first and last edges as 2 floats for each constraint. More...
ObiNativeFloatList parameters = new ObiNativeFloatList()
 Parameters of pinhole constraints. 5 floats per constraint (compliance, friction, motor speed, motor force and normalized coordinate along edge). More...
ObiNativeFloatList relativeVelocities = new ObiNativeFloatList()
 Relative velocities between rope and pinhole. More...
- Public Attributes inherited from Obi.ObiConstraintsBatch
ObiNativeIntList particleIndices = new ObiNativeIntList()
ObiNativeFloatList lambdas = new ObiNativeFloatList()
override void SwapConstraints (int sourceIndex, int destIndex)
- Protected Member Functions inherited from Obi.ObiConstraintsBatch
virtual void CopyConstraint (ObiConstraintsBatch batch, int constraintIndex)
void RegisterConstraint ()
Protected Attributes
IPinholeConstraintsBatchImpl m_BatchImpl
- Protected Attributes inherited from Obi.ObiConstraintsBatch
List< int > m_IDs = new List<int>()
List< int > m_IDToIndex = new List<int>()
int m_ConstraintCount = 0
int m_ActiveConstraintCount = 0
int m_InitialActiveConstraintCount = 0
override Oni.ConstraintType constraintType [get]
override IConstraintsBatchImpl implementation [get]
- Properties inherited from Obi.ObiConstraintsBatch
int constraintCount [get]
int activeConstraintCount [get, set]
virtual int initialActiveConstraintCount [get, set]
abstract Oni.ConstraintType constraintType [get]
abstract IConstraintsBatchImpl implementation [get]
- Properties inherited from Obi.IObiConstraintsBatch
ObiNativeIntList Obi.ObiPinholeConstraintsBatch.colliderIndices = new ObiNativeIntList()
ObiNativeFloatList Obi.ObiPinholeConstraintsBatch.edgeMus = new ObiNativeFloatList()
ObiNativeFloatList Obi.ObiPinholeConstraintsBatch.edgeRangeMus = new ObiNativeFloatList()
ObiNativeIntList Obi.ObiPinholeConstraintsBatch.edgeRanges = new ObiNativeIntList()
ObiNativeVector4List Obi.ObiPinholeConstraintsBatch.offsets = new ObiNativeVector4List()
ObiNativeFloatList Obi.ObiPinholeConstraintsBatch.parameters = new ObiNativeFloatList()
List<ObiActor> Obi.ObiPinholeConstraintsBatch.pinActors = new List<ObiActor>()
List<ObiColliderHandle> Obi.ObiPinholeConstraintsBatch.pinBodies = new List<ObiColliderHandle>()
ObiNativeFloatList Obi.ObiPinholeConstraintsBatch.relativeVelocities = new ObiNativeFloatList()
