Obi.ObiMeshRopeRenderSystem Class Reference
Inheritance diagram for Obi.ObiMeshRopeRenderSystem:
Obi.RenderSystem< T > Obi.IRenderSystem Obi.ComputeMeshRopeRenderSystem
 ObiMeshRopeRenderSystem (ObiSolver solver)
void Dispose ()
void Setup ()
void Step ()
virtual void Render ()
void BakeMesh (ObiRopeMeshRenderer renderer, ref Mesh mesh, bool transformToActorLocalSpace=false)
- Public Member Functions inherited from Obi.RenderSystem< T >
Type IRenderSystem. GetRendererType ()
virtual bool AddRenderer (T renderer)
virtual bool RemoveRenderer (T renderer)
virtual void PopulateBatches ()
virtual void CloseBatches ()
Protected Attributes
List< ObiRopeMeshRenderer > sortedRenderers = new List<ObiRopeMeshRenderer>()
VertexAttributeDescriptor[] layout
ObiSolver m_Solver
List< DynamicRenderBatch
< ObiRopeMeshRenderer > >
batchList = new List<DynamicRenderBatch<ObiRopeMeshRenderer>>()
MeshDataBatch meshData
ObiNativeList< int > meshIndices
ObiNativeList< int > pathSmootherIndices
ObiNativeList< BurstMeshData > rendererData
ObiNativeList< int > sortedIndices
ObiNativeList< int > sortedOffsets
ObiNativeList< int > vertexOffsets
ObiNativeList< int > vertexCounts
ObiPathSmootherRenderSystem pathSmootherSystem
Static Protected Attributes
static ProfilerMarker m_SetupRenderMarker = new ProfilerMarker("SetupMeshRopeRendering")
static ProfilerMarker m_RenderMarker = new ProfilerMarker("MeshRopeRendering")
Oni.RenderingSystemType typeEnum [get]
RendererSet< ObiRopeMeshRenderer > renderers [get]
- Properties inherited from Obi.RenderSystem< T >
RendererSet< T > renderers [get]
bool IRenderSystem. isEmpty [get]
- Properties inherited from Obi.IRenderSystem
uint tier [get]
bool isEmpty [get]
VertexAttributeDescriptor [] Obi.ObiMeshRopeRenderSystem.layout
protected
Initial value:
new VertexAttributeDescriptor(VertexAttribute.Position, VertexAttributeFormat.Float32, 3,0),
new VertexAttributeDescriptor(VertexAttribute.Normal, VertexAttributeFormat.Float32, 3,0),
new VertexAttributeDescriptor(VertexAttribute.Tangent, VertexAttributeFormat.Float32, 4,0),
new VertexAttributeDescriptor(VertexAttribute.Color, VertexAttributeFormat.Float32, 4,0),
new VertexAttributeDescriptor(VertexAttribute.TexCoord0, VertexAttributeFormat.Float32, 2,1),
new VertexAttributeDescriptor(VertexAttribute.TexCoord1, VertexAttributeFormat.Float32, 2,1),
new VertexAttributeDescriptor(VertexAttribute.TexCoord2, VertexAttributeFormat.Float32, 2,1),
new VertexAttributeDescriptor(VertexAttribute.TexCoord3, VertexAttributeFormat.Float32, 2,1),
ObiNativeList<int> Obi.ObiMeshRopeRenderSystem.pathSmootherIndices
protected
for each renderer, index of its path smoother in the path smoother system.
ObiNativeList<int> Obi.ObiMeshRopeRenderSystem.sortedIndices
protected
axis-sorted vertex indices.
ObiNativeList<int> Obi.ObiMeshRopeRenderSystem.sortedOffsets
protected
for each renderer, offset in the sortedIndices array.
List<ObiRopeMeshRenderer> Obi.ObiMeshRopeRenderSystem.sortedRenderers = new List<ObiRopeMeshRenderer>()
protected
temp list used to store renderers sorted by batch.
ObiNativeList<int> Obi.ObiMeshRopeRenderSystem.vertexCounts
protected
for each renderer, vertex count.
ObiNativeList<int> Obi.ObiMeshRopeRenderSystem.vertexOffsets
protected
for each renderer, vertex offset in its batch mesh data.
