Obi.ObiFluidEmitterBlueprint Class Reference
Inheritance diagram for Obi.ObiFluidEmitterBlueprint:
Obi.ObiEmitterBlueprintBase Obi.ObiActorBlueprint Obi.IObiParticleCollection
void OnValidate ()
float GetSmoothingRadius (Oni.SolverParameters.Mode mode)
- Public Member Functions inherited from Obi.ObiEmitterBlueprintBase
float GetParticleSize (Oni.SolverParameters.Mode mode)
float GetParticleMass (Oni.SolverParameters.Mode mode)
- Public Member Functions inherited from Obi.ObiActorBlueprint
delegate void BlueprintCallback (ObiActorBlueprint blueprint)
bool IsParticleActive (int index)
bool ActivateParticle (int index)
bool DeactivateParticle (int index)
void RecalculateBounds ()
IEnumerable< IObiConstraints > GetConstraints ()
int GetParticleRuntimeIndex (int blueprintIndex)
Vector3 GetParticlePosition (int index)
Quaternion GetParticleOrientation (int index)
Vector3 GetParticleRestPosition (int index)
Quaternion GetParticleRestOrientation (int index)
void GetParticleAnisotropy (int index, ref Vector4 b1, ref Vector4 b2, ref Vector4 b3)
float GetParticleMaxRadius (int index)
Color GetParticleColor (int index)
void GenerateImmediate ()
IEnumerator Generate ()
virtual void CommitBlueprintChanges ()
void Clear ()
ObiParticleGroup InsertNewParticleGroup (string name, int index, bool saveImmediately=true)
ObiParticleGroup AppendNewParticleGroup (string name, bool saveImmediately=true)
bool RemoveParticleGroupAt (int index, bool saveImmediately=true)
bool SetParticleGroupName (int index, string name, bool saveImmediately=true)
void ClearParticleGroups (bool registerUndo=true, bool saveImmediately=true)
virtual void RemoveSelectedParticles (ref bool[] selected, bool optimize=true)
void RestoreRemovedParticles ()
virtual void GenerateTethers (bool[] selected)
virtual void ClearTethers ()
float smoothing = 2f
float viscosity = 0.05f
float polarity = 1f
float vorticity = 0.0f
float buoyancy = -1.0f
float atmosphericDrag = 0.0f
float atmosphericPressure = 0.0f
float miscibility = 0.0f
Vector4 userData
- Public Attributes inherited from Obi.ObiEmitterBlueprintBase
uint capacity = 1000
float resolution = 1
float restDensity = 1000
- Public Attributes inherited from Obi.ObiActorBlueprint
Vector3[] positions = null
Vector4[] restPositions = null
Quaternion[] orientations = null
Quaternion[] restOrientations = null
Vector3[] velocities = null
Vector3[] angularVelocities = null
float[] invMasses = null
float[] invRotationalMasses = null
int[] filters = null
Vector3[] principalRadii = null
Color[] colors = null
int[] points = null
int[] edges = null
int[] triangles = null
ObiDistanceConstraintsData distanceConstraintsData = null
ObiBendConstraintsData bendConstraintsData = null
ObiSkinConstraintsData skinConstraintsData = null
ObiTetherConstraintsData tetherConstraintsData = null
ObiStretchShearConstraintsData stretchShearConstraintsData = null
ObiBendTwistConstraintsData bendTwistConstraintsData = null
ObiShapeMatchingConstraintsData shapeMatchingConstraintsData = null
ObiAerodynamicConstraintsData aerodynamicConstraintsData = null
ObiChainConstraintsData chainConstraintsData = null
ObiVolumeConstraintsData volumeConstraintsData = null
List< ObiParticleGroup > groups = new List<ObiParticleGroup>()
Additional Inherited Members
- Protected Member Functions inherited from Obi.ObiEmitterBlueprintBase
override IEnumerator Initialize ()
- Protected Member Functions inherited from Obi.ObiActorBlueprint
virtual void SwapWithFirstInactiveParticle (int index)
void GenerateChecksum ()
- Protected Attributes inherited from Obi.ObiActorBlueprint
uint m_Checksum
bool m_Empty = true
bool m_Edited = false
int m_InitialActiveParticleCount = 0
Bounds _bounds = new Bounds()
- Properties inherited from Obi.ObiActorBlueprint
uint checksum [get]
virtual bool usesTethers [get]
bool edited [get, set]
bool empty [get]
Bounds bounds [get]
- Events inherited from Obi.ObiActorBlueprint
BlueprintCallback OnBlueprintGenerate
float Obi.ObiFluidEmitterBlueprint.atmosphericDrag = 0.0f
amount of drag applied by the surrounding air to particles near the surface of the material.
float Obi.ObiFluidEmitterBlueprint.atmosphericPressure = 0.0f
amount of pressure applied by the surrounding air particles.
float Obi.ObiFluidEmitterBlueprint.buoyancy = -1.0f
how dense is this material with respect to air?
float Obi.ObiFluidEmitterBlueprint.polarity = 1f
higher polarity leads to higher surface tension. fluid of similar polarity are miscible.
Vector4 Obi.ObiFluidEmitterBlueprint.userData
values affected by miscibility
float Obi.ObiFluidEmitterBlueprint.viscosity = 0.05f
viscosity of the fluid
float Obi.ObiFluidEmitterBlueprint.vorticity = 0.0f
amount of vorticity confinement.
