| atmosphericDrag | Obi.ObiFluidEmitterBlueprint | |
| atmosphericPressure | Obi.ObiFluidEmitterBlueprint | |
| buoyancy | Obi.ObiFluidEmitterBlueprint | |
| capacity (defined in Obi.ObiEmitterBlueprintBase) | Obi.ObiEmitterBlueprintBase | |
| GetParticleMass(Oni.SolverParameters.Mode mode) | Obi.ObiEmitterBlueprintBase | |
| GetParticleSize(Oni.SolverParameters.Mode mode) | Obi.ObiEmitterBlueprintBase | |
| GetSmoothingRadius(Oni.SolverParameters.Mode mode) (defined in Obi.ObiFluidEmitterBlueprint) | Obi.ObiFluidEmitterBlueprint | |
| Initialize() (defined in Obi.ObiEmitterBlueprintBase) | Obi.ObiEmitterBlueprintBase | protectedvirtual |
| miscibility (defined in Obi.ObiFluidEmitterBlueprint) | Obi.ObiFluidEmitterBlueprint | |
| OnValidate() (defined in Obi.ObiFluidEmitterBlueprint) | Obi.ObiFluidEmitterBlueprint | |
| polarity | Obi.ObiFluidEmitterBlueprint | |
| resolution (defined in Obi.ObiEmitterBlueprintBase) | Obi.ObiEmitterBlueprintBase | |
| restDensity | Obi.ObiEmitterBlueprintBase | |
| smoothing (defined in Obi.ObiFluidEmitterBlueprint) | Obi.ObiFluidEmitterBlueprint | |
| userData | Obi.ObiFluidEmitterBlueprint | |
| viscosity | Obi.ObiFluidEmitterBlueprint | |
| vorticity | Obi.ObiFluidEmitterBlueprint | |
