13-09-2021, 11:33 AM
As described in the title, i'd like to import and export blueprint property using an image.
For example, i'd like to
the manual import/export instruction works fine with GUI.
But we have a large number of cloth models, and i don't know how to use this in a batch script.
In short, i'd like to use it as follows and wonder if it is possible:
Would you please help me how to do this properly?
- export initial skin radius values as an image,
- process the image in other tools, and
- import back it in unity in script.
// create the blueprint: (ObiClothBlueprint, ObiTearableClothBlueprint, ObiSkinnedClothBlueprint)
var blueprint = ScriptableObject.CreateInstance<ObiClothBlueprint>();
// set the input mesh:
blueprint.inputMesh = yourMesh;
// generate the blueprint:
yield return StartCoroutine(blueprint.Generate());
// import property values, e.g.
// blueprint.import(property="skinRadius", file="xxx.png", min=0, max=10) ??Would you please help me how to do this properly?
