Obi.ObiStitcher Class Reference
Inheritance diagram for Obi.ObiStitcher:
Classes
class  Stitch
void OnEnable ()
void OnDisable ()
int AddStitch (int particle1, int particle2)
void RemoveStitch (int index)
void Clear ()
void PushDataToSolver ()
ObiNativeIntList particleIndices
ObiNativeFloatList stiffnesses
ObiNativeFloatList lambdas
ObiActor Actor1 [get, set]
ObiActor Actor2 [get, set]
int StitchCount [get]
IEnumerable< Stitch > Stitches [get]
Detailed Description
ObiStitcher will create stitch constraints between 2 actors. All actors must be assigned to the same solver.
  • Add the constraint batch to the solver once all actors have been added.
  • If any of the actors is removed from the solver, remove the stitcher too.
  • Stitch constraints can keep n particles together, respecting their masses.
  • In edit mode, select the actors to be stitched and then select groups of particles and click "stitch". Or, create stitches by closeness.
Member Function Documentation
int Obi.ObiStitcher.AddStitch ( int  particle1,
int  particle2
Adds a new stitch to the stitcher. Note that unlike calling Clear(), AddStitch does not automatically perform a PushDataToSolver(). You should manually call it once you're done adding multiple stitches.
Parameters
indexof a particle in the first actor.
indexof a particle in the second actor.
Returns
constrant index, that can be used to remove it with a call to RemoveStitch.
void Obi.ObiStitcher.RemoveStitch ( int  index)
Removes. Note that unlike calling Clear(), AddStitch does not automatically perform a PushDataToSolver(). You should manually call it once you're done adding multiple stitches.
Parameters
constraintindex.
