| defaultSkinmap (defined in Obi.ObiSoftbodyBlueprintBase) | Obi.ObiSoftbodyBlueprintBase | |
| Initialize() (defined in Obi.ObiSoftbodyBlueprintBase) | Obi.ObiSoftbodyBlueprintBase | protectedvirtual |
| inputMesh | Obi.ObiMeshBasedActorBlueprint | |
| m_Skinmap (defined in Obi.ObiSoftbodyBlueprintBase) | Obi.ObiSoftbodyBlueprintBase | protected |
| rotation (defined in Obi.ObiMeshBasedActorBlueprint) | Obi.ObiMeshBasedActorBlueprint | |
| scale (defined in Obi.ObiMeshBasedActorBlueprint) | Obi.ObiMeshBasedActorBlueprint | |
