| _aerodynamicsEnabled (defined in Obi.ObiClothBase) | Obi.ObiClothBase | protected |
| _bendCompliance (defined in Obi.ObiClothBase) | Obi.ObiClothBase | protected |
| _bendConstraintsEnabled (defined in Obi.ObiClothBase) | Obi.ObiClothBase | protected |
| _distanceConstraintsEnabled (defined in Obi.ObiClothBase) | Obi.ObiClothBase | protected |
| _drag (defined in Obi.ObiClothBase) | Obi.ObiClothBase | protected |
| _lift (defined in Obi.ObiClothBase) | Obi.ObiClothBase | protected |
| _maxBending (defined in Obi.ObiClothBase) | Obi.ObiClothBase | protected |
| _maxCompression (defined in Obi.ObiClothBase) | Obi.ObiClothBase | protected |
| _plasticCreep (defined in Obi.ObiClothBase) | Obi.ObiClothBase | protected |
| _plasticYield (defined in Obi.ObiClothBase) | Obi.ObiClothBase | protected |
| _stretchCompliance (defined in Obi.ObiClothBase) | Obi.ObiClothBase | protected |
| _stretchingScale (defined in Obi.ObiClothBase) | Obi.ObiClothBase | protected |
| _tetherCompliance (defined in Obi.ObiSkinnedCloth) | Obi.ObiSkinnedCloth | protected |
| _tetherConstraintsEnabled (defined in Obi.ObiSkinnedCloth) | Obi.ObiSkinnedCloth | protected |
| _tetherScale (defined in Obi.ObiSkinnedCloth) | Obi.ObiSkinnedCloth | protected |
| aerodynamicsEnabled | Obi.ObiClothBase | |
| bakedNormals (defined in Obi.ObiSkinnedCloth) | Obi.ObiSkinnedCloth | |
| bakedTangents (defined in Obi.ObiSkinnedCloth) | Obi.ObiSkinnedCloth | |
| bakedVertices (defined in Obi.ObiSkinnedCloth) | Obi.ObiSkinnedCloth | |
| bendCompliance | Obi.ObiClothBase | |
| bendConstraintsEnabled | Obi.ObiClothBase | |
| clothBlueprintBase (defined in Obi.ObiSkinnedCloth) | Obi.ObiSkinnedCloth | |
| distanceConstraintsEnabled | Obi.ObiClothBase | |
| drag | Obi.ObiClothBase | |
| GetDeformableEdgeCount() (defined in Obi.ObiActor) | Obi.ObiActor | virtual |
| GetDrag(ObiAerodynamicConstraintsBatch batch, int constraintIndex) (defined in Obi.ObiClothBase) | Obi.ObiClothBase | |
| GetLift(ObiAerodynamicConstraintsBatch batch, int constraintIndex) (defined in Obi.ObiClothBase) | Obi.ObiClothBase | |
| GetSkinCompliance(ObiSkinConstraintsBatch batch, int constraintIndex) (defined in Obi.ObiSkinnedCloth) | Obi.ObiSkinnedCloth | |
| GetSkinRadiiBackstop(ObiSkinConstraintsBatch batch, int constraintIndex) (defined in Obi.ObiSkinnedCloth) | Obi.ObiSkinnedCloth | |
| lift | Obi.ObiClothBase | |
| m_OneSided (defined in Obi.ObiClothBase) | Obi.ObiClothBase | protected |
| m_SelfCollisions (defined in Obi.ObiClothBase) | Obi.ObiClothBase | protected |
| m_SkinnedClothBlueprint (defined in Obi.ObiSkinnedCloth) | Obi.ObiSkinnedCloth | protected |
| maxBending | Obi.ObiClothBase | |
| maxCompression | Obi.ObiClothBase | |
| OnDisable() (defined in Obi.ObiSkinnedCloth) | Obi.ObiSkinnedCloth | protectedvirtual |
| OnEnable() (defined in Obi.ObiSkinnedCloth) | Obi.ObiSkinnedCloth | protectedvirtual |
| oneSided | Obi.ObiClothBase | |
| OnValidate() (defined in Obi.ObiSkinnedCloth) | Obi.ObiSkinnedCloth | protectedvirtual |
| plasticCreep | Obi.ObiClothBase | |
| plasticYield | Obi.ObiClothBase | |
| ProvideDeformableEdges(ObiNativeIntList deformableEdges) (defined in Obi.ObiActor) | Obi.ObiActor | virtual |
| ProvideDeformableTriangles(ObiNativeIntList deformableTriangles, ObiNativeVector2List deformableUVs) (defined in Obi.ObiClothBase) | Obi.ObiClothBase | virtual |
| RequestReadback() (defined in Obi.ObiActor) | Obi.ObiActor | virtual |
| selfCollisions | Obi.ObiClothBase | |
| SimulationEnd(float simulatedTime, float substepTime) (defined in Obi.ObiActor) | Obi.ObiActor | virtual |
| SimulationStart(float timeToSimulate, float substepTime) (defined in Obi.ObiActor) | Obi.ObiActor | virtual |
| skinConstraintsEnabled (defined in Obi.ObiSkinnedCloth) | Obi.ObiSkinnedCloth | |
| skinnedClothBlueprint (defined in Obi.ObiSkinnedCloth) | Obi.ObiSkinnedCloth | |
| sourceBlueprint (defined in Obi.ObiSkinnedCloth) | Obi.ObiSkinnedCloth | |
| stretchCompliance | Obi.ObiClothBase | |
| stretchingScale | Obi.ObiClothBase | |
| tetherCompliance | Obi.ObiSkinnedCloth | |
| tetherConstraintsEnabled | Obi.ObiSkinnedCloth | |
| tetherScale | Obi.ObiSkinnedCloth | |
| triangleSetID | Obi.ObiClothBase | protected |
| usesOrientedParticles | Obi.ObiActor | |
