void | CalculateMu () |
void | CalculateRange () |
void | Bind () |
| ObiActor | rope [get] |
| | The rope this attachment is added to. More...
float | edgeCoordinate [get] |
int | edgeIndex [get] |
| Transform | target [get, set] |
| | The target transform that the pinhole should be attached to. More...
| float | position [get, set] |
| | Normalized coordinate of the point along the rope where the pinhole is positioned. More...
bool | limitRange [get, set] |
| Vector2 | range [get, set] |
| bool | isBound [get] |
| | Whether this pinhole is currently bound or not. More...
| float | compliance [get, set] |
| | Constraint compliance. More...
float | friction [get, set] |
float | motorSpeed [get, set] |
float | motorForce [get, set] |
bool | clampAtEnds [get, set] |
float | relativeVelocity [get, set] |
| float Obi.ObiPinhole.breakThreshold = float.PositiveInfinity |
Force threshold above which the pinhole should break.
| float Obi.ObiPinhole.compliance |
getset |
High compliance values will increase the pinhole's elasticity.
| bool Obi.ObiPinhole.isBound |
get |
| float Obi.ObiPinhole.position |
getset |
| Vector2 Obi.ObiPinhole.range |
getset |
| Transform Obi.ObiPinhole.target |
getset |
- Assets/Obi/Scripts/RopeAndRod/Utils/ObiPinhole.cs
