| enum | AttachmentType { Static,
Dynamic
| float | breakThreshold = float.PositiveInfinity |
| | Force thershold above which the attachment should break. More...
| float Obi.ObiParticleAttachment.breakThreshold = float.PositiveInfinity |
Only affects dynamic attachments, as static attachments do not work with forces.
| ObiActor Obi.ObiParticleAttachment.actor |
get |
The actor this attachment is added to.
| AttachmentType Obi.ObiParticleAttachment.attachmentType |
getset |
Type of attachment, can be either static or dynamic.
| float Obi.ObiParticleAttachment.compliance |
getset |
Constraint compliance, in case this attachment is dynamic.
High compliance values will increase the attachment's elasticity.
| bool Obi.ObiParticleAttachment.constrainOrientation |
getset |
Should this attachment constraint particle orientations too?
| bool Obi.ObiParticleAttachment.isBound |
get |
Whether this attachment is currently bound or not.
The particle group that should be attached to the target.
| Transform Obi.ObiParticleAttachment.target |
getset |
The target transform that the particleGroup should be attached to.
- Assets/Obi/Scripts/Common/Utils/ObiParticleAttachment.cs
