Obi.ObiExtrudedRopeRenderSystem Class Referenceabstract
Inheritance diagram for Obi.ObiExtrudedRopeRenderSystem:
Obi.RenderSystem< T > Obi.IRenderSystem Obi.ComputeExtrudedRopeRenderSystem
 ObiExtrudedRopeRenderSystem (ObiSolver solver)
void Dispose ()
virtual void Setup ()
abstract void Render ()
void Step ()
void BakeMesh (ObiRopeExtrudedRenderer renderer, ref Mesh mesh, bool transformToActorLocalSpace=false)
- Public Member Functions inherited from Obi.RenderSystem< T >
Type IRenderSystem. GetRendererType ()
virtual bool AddRenderer (T renderer)
virtual bool RemoveRenderer (T renderer)
Protected Attributes
List< ObiRopeExtrudedRenderer > sortedRenderers = new List<ObiRopeExtrudedRenderer>()
VertexAttributeDescriptor[] layout
ObiSolver m_Solver
SubMeshDescriptor subMeshDescriptor = new SubMeshDescriptor(0, 0)
List< ProceduralRenderBatch
< ProceduralRopeVertex > >
batchList = new List<ProceduralRenderBatch<ProceduralRopeVertex>>()
ObiNativeList
< BurstExtrudedMeshData >
rendererData
ObiNativeList< int > pathSmootherIndices
Dictionary< ObiRopeSection, int > sectionToIndex = new Dictionary<ObiRopeSection, int>()
ObiNativeVector2List sectionData
ObiNativeList< int > sectionOffsets
ObiNativeList< int > sectionIndices
ObiNativeList< int > vertexOffsets
ObiNativeList< int > triangleOffsets
ObiNativeList< int > vertexCounts
ObiNativeList< int > triangleCounts
ObiPathSmootherRenderSystem pathSmootherSystem
Static Protected Attributes
static ProfilerMarker m_SetupRenderMarker = new ProfilerMarker("SetupExtrudedRopeRendering")
static ProfilerMarker m_RenderMarker = new ProfilerMarker("ExtrudedRopeRendering")
Oni.RenderingSystemType typeEnum [get]
RendererSet
renderers [get]
- Properties inherited from Obi.RenderSystem< T >
RendererSet< T > renderers [get]
bool IRenderSystem. isEmpty [get]
- Properties inherited from Obi.IRenderSystem
uint tier [get]
bool isEmpty [get]
VertexAttributeDescriptor [] Obi.ObiExtrudedRopeRenderSystem.layout
protected
Initial value:
new VertexAttributeDescriptor(VertexAttribute.Position, VertexAttributeFormat.Float32, 3),
new VertexAttributeDescriptor(VertexAttribute.Normal, VertexAttributeFormat.Float32, 3),
new VertexAttributeDescriptor(VertexAttribute.Tangent, VertexAttributeFormat.Float32, 4),
new VertexAttributeDescriptor(VertexAttribute.Color, VertexAttributeFormat.Float32, 4),
new VertexAttributeDescriptor(VertexAttribute.TexCoord0, VertexAttributeFormat.Float32, 2),
ObiNativeList<int> Obi.ObiExtrudedRopeRenderSystem.pathSmootherIndices
protected
renderer indices, sorted by batch
ObiNativeList<BurstExtrudedMeshData> Obi.ObiExtrudedRopeRenderSystem.rendererData
protected
for each renderer, data about smoother.
ObiNativeList<int> Obi.ObiExtrudedRopeRenderSystem.sectionIndices
protected
for each renderer, index of the section used.
ObiNativeList<int> Obi.ObiExtrudedRopeRenderSystem.sectionOffsets
protected
for each section, offset of its first entry in the sectionData array.
List<ObiRopeExtrudedRenderer> Obi.ObiExtrudedRopeRenderSystem.sortedRenderers = new List<ObiRopeExtrudedRenderer>()
protected
temp list used to store renderers sorted by batch.
ObiNativeList<int> Obi.ObiExtrudedRopeRenderSystem.triangleCounts
protected
for each renderer, triangle count.
ObiNativeList<int> Obi.ObiExtrudedRopeRenderSystem.triangleOffsets
protected
for each renderer, triangle offset in its batch mesh data.
ObiNativeList<int> Obi.ObiExtrudedRopeRenderSystem.vertexCounts
protected
for each renderer, vertex count.
ObiNativeList<int> Obi.ObiExtrudedRopeRenderSystem.vertexOffsets
protected
for each renderer, vertex offset in its batch mesh data.
