This is the complete list of members for Obi.ObiBone, including all inherited members.
| _aerodynamicsEnabled (defined in Obi.ObiBone) | Obi.ObiBone | protected |
| _bend1Compliance (defined in Obi.ObiBone) | Obi.ObiBone | protected |
| _bend2Compliance (defined in Obi.ObiBone) | Obi.ObiBone | protected |
| _bendTwistConstraintsEnabled (defined in Obi.ObiBone) | Obi.ObiBone | protected |
| _drag (defined in Obi.ObiBone) | Obi.ObiBone | protected |
| _lift (defined in Obi.ObiBone) | Obi.ObiBone | protected |
| _mass (defined in Obi.ObiBone) | Obi.ObiBone | protected |
| _plasticCreep (defined in Obi.ObiBone) | Obi.ObiBone | protected |
| _plasticYield (defined in Obi.ObiBone) | Obi.ObiBone | protected |
| _radius (defined in Obi.ObiBone) | Obi.ObiBone | protected |
| _rotationalMass (defined in Obi.ObiBone) | Obi.ObiBone | protected |
| _shear1Compliance (defined in Obi.ObiBone) | Obi.ObiBone | protected |
| _shear2Compliance (defined in Obi.ObiBone) | Obi.ObiBone | protected |
| _skinCompliance (defined in Obi.ObiBone) | Obi.ObiBone | protected |
| _skinConstraintsEnabled (defined in Obi.ObiBone) | Obi.ObiBone | protected |
| _skinRadius (defined in Obi.ObiBone) | Obi.ObiBone | protected |
| _stretchCompliance (defined in Obi.ObiBone) | Obi.ObiBone | protected |
| _stretchShearConstraintsEnabled (defined in Obi.ObiBone) | Obi.ObiBone | protected |
| _torsionCompliance (defined in Obi.ObiBone) | Obi.ObiBone | protected |
| aerodynamicsEnabled | Obi.ObiBone | |
| Awake() (defined in Obi.ObiBone) | Obi.ObiBone | protectedvirtual |
| bend1Compliance | Obi.ObiBone | |
| bend2Compliance | Obi.ObiBone | |
| bendTwistConstraintsEnabled | Obi.ObiBone | |
| boneBlueprint (defined in Obi.ObiBone) | Obi.ObiBone | |
| drag | Obi.ObiBone | |
| Filter | Obi.ObiBone | |
| FixedUpdate() (defined in Obi.ObiBone) | Obi.ObiBone | |
| fixRoot (defined in Obi.ObiBone) | Obi.ObiBone | |
| GetBendTwistCompliance(ObiBendTwistConstraintsBatch batch, int constraintIndex) (defined in Obi.ObiBone) | Obi.ObiBone | |
| GetBendTwistPlasticity(ObiBendTwistConstraintsBatch batch, int constraintIndex) (defined in Obi.ObiBone) | Obi.ObiBone | |
| GetDeformableEdgeCount() (defined in Obi.ObiActor) | Obi.ObiActor | virtual |
| GetDrag(ObiAerodynamicConstraintsBatch batch, int constraintIndex) (defined in Obi.ObiBone) | Obi.ObiBone | |
| GetLift(ObiAerodynamicConstraintsBatch batch, int constraintIndex) (defined in Obi.ObiBone) | Obi.ObiBone | |
| GetSkinCompliance(ObiSkinConstraintsBatch batch, int constraintIndex) (defined in Obi.ObiBone) | Obi.ObiBone | |
| GetSkinRadiiBackstop(ObiSkinConstraintsBatch batch, int constraintIndex) (defined in Obi.ObiBone) | Obi.ObiBone | |
| GetStretchShearCompliance(ObiStretchShearConstraintsBatch batch, int constraintIndex) (defined in Obi.ObiBone) | Obi.ObiBone | |
| ignored (defined in Obi.ObiBone) | Obi.ObiBone | |
| LateUpdate() (defined in Obi.ObiBone) | Obi.ObiBone | |
| lift | Obi.ObiBone | |
| m_BoneBlueprint (defined in Obi.ObiBone) | Obi.ObiBone | protected |
| m_SelfCollisions (defined in Obi.ObiBone) | Obi.ObiBone | protected |
| mass | Obi.ObiBone | |
| OnDestroy() (defined in Obi.ObiBone) | Obi.ObiBone | protectedvirtual |
| OnDisable() (defined in Obi.ObiActor) | Obi.ObiActor | protectedvirtual |
| OnEnable() (defined in Obi.ObiActor) | Obi.ObiActor | protectedvirtual |
| OnValidate() (defined in Obi.ObiBone) | Obi.ObiBone | protectedvirtual |
| plasticCreep | Obi.ObiBone | |
| plasticYield | Obi.ObiBone | |
| ProvideDeformableEdges(ObiNativeIntList deformableEdges) (defined in Obi.ObiBone) | Obi.ObiBone | virtual |
| ProvideDeformableTriangles(ObiNativeIntList deformableTriangles, ObiNativeVector2List deformableUVs) (defined in Obi.ObiActor) | Obi.ObiActor | virtual |
| radius | Obi.ObiBone | |
| RequestReadback() (defined in Obi.ObiBone) | Obi.ObiBone | virtual |
| ResetToCurrentShape() | Obi.ObiBone | |
| rotationalMass | Obi.ObiBone | |
| selfCollisions | Obi.ObiBone | |
| shear1Compliance | Obi.ObiBone | |
| shear2Compliance | Obi.ObiBone | |
| SimulationEnd(float simulatedTime, float substepTime) (defined in Obi.ObiBone) | Obi.ObiBone | virtual |
| SimulationStart(float timeToSimulate, float substepTime) (defined in Obi.ObiBone) | Obi.ObiBone | virtual |
| skinCompliance | Obi.ObiBone | |
| skinConstraintsEnabled | Obi.ObiBone | |
| skinRadius | Obi.ObiBone | |
| sourceBlueprint (defined in Obi.ObiBone) | Obi.ObiBone | |
| stretchBones (defined in Obi.ObiBone) | Obi.ObiBone | |
| stretchCompliance | Obi.ObiBone | |
| stretchShearConstraintsEnabled | Obi.ObiBone | |
| torsionCompliance | Obi.ObiBone | |
| UpdateBlueprint() (defined in Obi.ObiBone) | Obi.ObiBone | |
| UpdateMasses() (defined in Obi.ObiBone) | Obi.ObiBone | |
| UpdateRadius() (defined in Obi.ObiBone) | Obi.ObiBone | |
| usesOrientedParticles | Obi.ObiActor |
