Help  Make cloth grow if inside collider?
Any way to make a cloth grow if it is completely inside a collider? For example, a XS tshirt inside of a very big guy. Any way to make it stretch to fit the guy?
Thanks.
(07-12-2018, 04:16 PM)aelbannan Wrote: Hi,
Thanks.
Not in a very controllable or meaningful way for your purpose, but can be done to some extent.
You can stretch or enlarge cloth by altering the distance constraints' stretching scale property:
You can also tell if particles are close or inside a collider by using collision callbacks:
(07-12-2018, 05:04 PM)josemendez Wrote: Not in a very controllable or meaningful way for your purpose, but can be done to some extent.
Thank you!
Is there any way to programatically move a particle (give it a new position)? I'm not having any luck finding this in the API.
(08-12-2018, 04:36 AM)aelbannan Wrote: Thank you!
Yep. Use Oni.SetParticlePositions(). See:
(08-12-2018, 02:15 PM)josemendez Wrote: Yep. Use Oni.SetParticlePositions(). See:
Thank you!
