Compatibility with Oculus Go ?
Pregunta
I need to use Obi Cloth on a Oculus Go.
On Unity Editor (2017.4 LTS), all seems to work well. However, when I'm building and trying on the Oculus Go, the cloth is freezed. Nothing moves.
I tested the Unity Cloth component, which works fine.
Is it a known issue, do you have a workaround or is it simply not possible?
Thanks !  Sonrisa
Okay I managed to make it works. Interesante
I used Unity Cloud Build before, which was the problem.
When I did the build on my own computer, it worked like a charm.
Maybe I or you have something to do in order to make it compatible with Unity Cloud Build ?
Thanks !  Corazón
