Help  How to reduce fluid scatter on collision
I am creating tap water using obi fluid in the oculus quest. If the virtual hand model collides with water, it scatters more.
How to reduce water scatter on collision?
(30-08-2022, 04:21 PM)balaji.v Wrote: Hi,
You probably want to reduce the solver's "max depenetration" parameter:
This will clamp the maximum velocity at which particles can be projected out of colliders.
