The ObiSolver component is arguably the most important component in Obi. It is responsible for simulating particle physics and enforcing constraints. Three important things to remember about solvers:
Solvers always perform the simulation in local space. This means that translating, rotating or scaling the solver will rigidly transform the simulation as a whole.
You can inject a percentage of the solver linear/rotational movement back into the simulation, in the form of inertial forces. For instance, you might want to control how much of the overall character movement will affect the clothing simulation. For this purpose, solvers expose two parameters to independently control linear and rotational inertial forces (see below).
The solver inspector is organized in 4 foldable panels, each one contains parameters affecting one specific aspect of the solver's behavior.
These settings control how the solver works internally:
Which simulation backend to use. If any given backend is not available, Obi will try to fall back to the Oni backend. See the backends page for more information.
The solver can simulate in 2D or 3D mode. In 2D mode, simulation only happens in the XY plane.
Interpolation mode used to render particles. None is faster to calculate, but Interpolate will give more visually pleasing results. However, Interpolate will introduce a 1-frame delay between the actual physical location of particles and the position they're rendered at. Keep this in mind when using interpolation around other objects in the scene. If you have rigidbodies interacting with Obi, it is generally a good idea to either use interpolation for both, or not use it at all.
Various global parameters regarding external/internal forces, such as gravity, damping, inertia, etc:
Whether to apply gravity in the solver's local space (Self) or in world space (World). If set to "Self", the direction of gravity will rotate together with the solver.
Direction and magnitude of gravity applied to particles in this solver, expressed in the solver's local space.
Any particle with a kinetic energy below this value will be freezed in place. This is useful when you don´t want minuscule variations in velocity or force to perturb an actor, making it look like its jittering or moving very slowly. Set it to zero if you want your particles' positions to be affected by any force that acts upon them, however small it may be.
Velocity damping applied to particle velocities. Increase it to reduce their kinetic energy.
Controls how much of the world-space linear inertia of the solver transform is applied to the particles. Values range from 0 (none) to 1 (100% of it).
Analogous to the previous property, but controls angular inertia (rotations) instead of linear inertia (translations). Note that centrifugal and coriolis forces are accounted for.
Fluid particles in Obi can be ellipsoidal in shape, instead of perfectly spherical. This is used to better adapt their shape to the surface of the object they represent, achieving more accurate collision detection and smoother rendering. Max anistropy lets you determine the maximum ratio between the ellipsoid's radii: a value of 1 will force all particles to be spherical (deactivates anisotropy), values larger than 1 will allow particles to become more ellipsoidal the higher max anisotropy is.
Should this solver keep the simulation going when invisible to all cameras? Keep this enabled if your simulation needs to be updated at all times, disable it to improve performance when multiple solvers exist in the scene but they are not visible at all times.
These control the solver's collision detection pipeline:
Percentage of particle/rigidbody velocity used to expand their bounding box during collision detection. A value of 1 will use 100% of the velocity, resulting in full continuous collision detection. A value of 0 will result in purely static collision detection.
Margin added to particle bounding boxes (after CCD expansion), used when generating contacts. Any colliders within the particle's bounding box will be considered for contact generation. This value should be kept relatively low. Large values will generate more contacts, which can improve robustness in very complex scenes, but will negatively affect performance.
Maximum velocity (in meters/second) applied to particles to take them out of a collider. This only applies to particles that start the physics step already inside a collider. Low values will gently take the particle out of the collider. High values allow the solver to take the particle out immediately, causing it to "jump" out of colliders.
High values will artificially increase the mass of particles supporting other particles. Use it to obtain better stacking stability.
Maximum amount of iterations performed to refine surface collisions.
Tolerance threshold below which surface collision refinement will stop. Increasing it a bit can help obtain more stable surface collisions against flat surfaces.
You can globally enable/disable each constraint type for all actors being managed by the solver. Disabling constraints this way (as opposed to disabling constraint components for individual actors) will allow the solver to completely skip any calculations related to that specific constraint type.
For instance, if you disable collision constraints and particle collision constraints, the entire collision detection pipeline is skipped. This allows you to customize what's being done under the hood and get rid of unnecessary overhead.
ObiSolver exposes 4 parameters for each constraint type:
Are these constraints updated at all? By default all constraint types are enabled, altough this is rarely what you want for production-ready simulations. You should disable any constraints that are not critical for the final look of your simulation.
How many times per substep should these constraints be evaluated? A high iteration count will keep the simulation closer to the ground-truth solution. Keep it low if these constraints aren`t very important for your particular purpose and you want to get better performance. The default is 3.
Determines how to enforce constraints of this kind. There are two modes:
The following images show a rope that's been stretched way past its rest length, using different evaluation modes for distance constraints. In sequential mode (left), a clumping pattern in particle placement caused by order-dependent evaluation is clearly visible. In parallel mode (right) all particles are evenly spaced, but the rope sags a bit more due to reduced convergence speed.
Here's another example: some rigidbodies on a trampoline. Cloth tension is mapped to a color gradient for visualization purposes. In sequential mode (left), tension is unevenly distributed over the cloth's surface, resulting in a noisy color pattern. In parallel mode (right) tension is evenly distributed, but the cloth is more elastic due to reduced convergence speed.
Successive Over-Relaxation (SOR) factor. When trying to satisfy constraints, one way to improve convergence is to “over-relax” the constraints. That is, if moving a particle 2 units to the left would satisfy the constraint for now, why not moving it 3 units? This is exactly what this factor is used for. 1 is the default value, which does not perform over-relaxation at all. 2 is the maximum, which allows you to perform twice as much (200%) relaxation on constraints. High values can be used to help speed up convergence in any of the two modes (sequential or parallel), but keep in mind that simulation stability can degrade. Values lower than 1 will only partially enforce constraints. For instance, with a relaxation factor of 0.25 constraints will only have a 25% of their normal effect.
