2 way Particle Attachments
Hi
I want to achieve something similar to the chain example.
I have created a small rope with 2 particle attachments. The one is static ,  and the other one is dynamic. The dynamic attachment is the red ball bellow which has a rigidbody. When I run it , the problem is that the ball with the rope doesn't follow the rest of the gameobject and the length of the rope extends.
(12-05-2021, 02:53 PM)tpaslou Wrote: Hi
This should work, given the info you gave.
-Is your rigidbody “kinematic for particles” enabled? That will cause the rigidbody to have infinite mass.
- what’s the mass of the rigidbody?
- how many substeps are you using? (Found in ObiFixedUpdater component)
(12-05-2021, 03:11 PM)josemendez Wrote: Hi,
I had to disable Kinematic for Particles.
Thank you !
