28-02-2019, 04:08 PM
First, thanks for your GREAT ASSET!! I'm getting an issue trying to setup handles with ropes...
I using Unity 2018.3.2f1 and Obi Rope. First your example scene does not work as far as the handle are concern, I've noticed that and it is may be linked to my problem :
When I setup a Rod I get all the button to fix particle and create an handle.
When I setup a Rope, the button "fix translation and orientation" is not active and the Handle setup does not work
I'm then not able to make Handle working with Ropes. I made many many trials and I pretty sure it is not a setting problem...
Any ideas?
Thanks a lot!
JF
Any ideas?
Thanks a lot!
JF
