06-12-2025, 11:39 AM
I'm trying to make Obi Fluids interact with Voxelica voxel engine, which generates chunk-based mesh colliders at runtime. However, as the Mesh objects are being modified on the Mesh Colliders, Obi Solver doesn't seem to pick up on the change. I tried manually forcing an update with several different methods in the Obi interfaces but had no luck so far. I also noticed that the GPU Solver and CPU Solver behaved differently, where CPU solvers was able to pick up on the changes with a specific combination of calls but GPU Solver wasn't. Sorry that I don't have the specific methods in mind at the moment, but I'm hoping that you can point me in the right direction.
Thanks!
Thanks!
