Suggestion / Idea  The Limitation of Using Obi System Only as a Child of the Solver Is Meaningless
A structural limitation of the current Obi system is that it must be placed as a child of the solver.
If each solver were simply given a name, and actors could specify which solver to use by name, the system would become much more versatile.
Please check the attached video.
That would be a really bad design choice, and quite limiting as it doesn’t allow for a proper inertial frame of reference implementation - which is central to how Obi works - or local space simulation without many edge cases which are detrimental to performance.
It’s how Obi 1.0 used to work (instead of a name, actors had a *reference* to an arbitrary solver), we but quickly moved on from it. See:
https://obi.virtualmethodstudio.com/foru...l#pid17184
Kind regards,
