06-08-2020, 12:10 PM
(This post was last modified: 06-08-2020, 12:20 PM by muzzammilnaeem.)
I'm using Obi fluid version 5.4
i have like 400 small cubes in a bucket and has set the viscosity of the fluid to 1
What i want is the fluid to stick to objects can you please guide me on how to do this.
like i wanna do is put some fluid on the cubes in the first picture i have made in the bucket but want it to be sticked on it
but getting the 2nd picture result..
Thanks..
1st picture link : https://drive.google.com/file/d/1Oux3-En...sp=sharing
2nd picture link : https://drive.google.com/file/d/1s1IqElP...sp=sharing
06-08-2020, 12:19 PM
(This post was last modified: 06-08-2020, 12:19 PM by josemendez.)
(06-08-2020, 12:10 PM)muzzammilnaeem Wrote: Hi,
Thanks..
Stickiness is not an internal fluid property (unlike viscosity), but a collision property.
Use a custom collision material for your emitter, then set its friction and stickiness to around 0.8 and stick distance to 0.02. Check the collisions manual page for more info:
Also check the FluidViscosity sample scene for a fluid that's both viscous and sticky.
(06-08-2020, 12:19 PM)josemendez Wrote: Hi there,
Also check the FluidViscosity sample scene for a fluid that's both viscous and sticky. https://drive.google.com/file/d/1s1IqElP...sp=sharing
Hi jose,
I have one more question regarding the issue can u please view the link and suggest me more about that i'm new to using this plugin..
(06-08-2020, 12:22 PM)muzzammilnaeem Wrote: https://drive.google.com/file/d/1s1IqElP...sp=sharing
Hi jose,
The link is just a screenshot of a bowl with fluid and some ice cubes, what exactly do you need help with?
(06-08-2020, 12:31 PM)josemendez Wrote: Hi there,
The link is just a screenshot of a bowl with fluid and some ice cubes, what exactly do you need help with? Hi there,
I don't want the fluid to go into the bowl but to be attached to the ice cubes..
like a juice on the ice cubes.
not juice filled with ice cubes..
(06-08-2020, 12:34 PM)muzzammilnaeem Wrote: Hi there,
You can have the fluid stick to the cubes by setting the collision material stickiness, but it won't be perfectly attached to it like a parented transform would. Is this what you were looking for, kinda like a coating?
(06-08-2020, 12:39 PM)josemendez Wrote: You can have the fluid stick to the cubes by setting the collision material stickiness, but it won't be perfectly attached to it like a parented transform would. Is this what you were looking for, kinda like a coating?
yes like coating the cubes with fluid
06-08-2020, 01:00 PM
(This post was last modified: 06-08-2020, 01:01 PM by josemendez.)
(06-08-2020, 12:44 PM)muzzammilnaeem Wrote: yes like coating the cubes with fluid
Then why do you need it to be fluid, if it's going to be a solid coating around the cubes?  Using a simple mesh on top of the cubes would be way simpler...
If you want to retain the fluid-like motion, using stickiness is the way to go then.
I'm gonna go with the fluid like motion it's more realistic.
Thanks for your help..
Almost getting there
