Help Creating a bungee cord between two objects - Printable Version +- Obi Official Forum (https://obi.virtualmethodstudio.com/forum) +-- Forum: Obi Users Category (https://obi.virtualmethodstudio.com/forum/forum-1.html) +--- Forum: Obi Rope (https://obi.virtualmethodstudio.com/forum/forum-4.html) +--- Thread: Help Creating a bungee cord between two objects (/thread-2416.html) |
Creating a bungee cord between two objects - Bluerex - 10-08-2020 Hi, I am trying to create a bungee cord between two objects that can have opposite resistances. When one object pulls too far, the bungee spring effect snaps in and brings the two objects together using physics. I've gotten reasonable results with Obi doing this, but nothing has felt perfect... I am pretty new to Obi Rope so I was just hoping someone could throw some me some pointers on how to achieve this:
Thanks for the help! RE: Creating a bungee cord between two objects - josemendez - 12-08-2020 (10-08-2020, 05:11 PM)Bluerex Wrote: Hi, Hi there, Reading the manual will answer most of your questions right away :Connect a rope between two objects.:Use attachments. See: http://obi.virtualmethodstudio.com/tutorials/attachments.html Have the rope length be finite: Use more substeps. See: http://obi.virtualmethodstudio.com/tutorials/convergence.html When the rope is stretched too far, it 'snaps back' (instead of breaking): Disable the "tearable" checkbox in the rope. This causes the two objects to snap towards each other using physics: Should happen automatically with all the above. Quote:As a bonus, I'd like to play with the idea that the rope still acts as a cord between the two objects, but doesn't interact with other objects in the scene. This is what happens by default. Unless you add a ObiCollider component to an object, the rope won't interact with it. See: http://obi.virtualmethodstudio.com/tutorials/collisions.html |
