Bug / Crash  Random null error when editing cloth BP
I can edit the cloth blueprint few times and after 5th or sometimes second it dissapears and gives null errors
Obi.ObiActorBlueprintEditor.OnSceneGUI (UnityEditor.SceneView sceneView) (at Assets/Obi/Editor/Common/Blueprints/ObiActorBlueprintEditor.cs:311)
UnityEditor.SceneView.CallOnSceneGUI () (at <8c48e4bc2ff34638b69095cbb65e2e27>:0)
UnityEditor.SceneView.HandleSelectionAndOnSceneGUI () (at <8c48e4bc2ff34638b69095cbb65e2e27>:0)
UnityEditor.SceneView.OnGUI () (at <8c48e4bc2ff34638b69095cbb65e2e27>:0)
UnityEditor.HostView.InvokeOnGUI (UnityEngine.Rect onGUIPosition, UnityEngine.Rect viewRect) (at <8c48e4bc2ff34638b69095cbb65e2e27>:0)
UnityEditor.DockArea.DrawView (UnityEngine.Rect viewRect, UnityEngine.Rect dockAreaRect) (at <8c48e4bc2ff34638b69095cbb65e2e27>:0)
UnityEditor.DockArea.OldOnGUI () (at <8c48e4bc2ff34638b69095cbb65e2e27>:0)
UnityEngine.UIElements.IMGUIContainer.DoOnGUI (UnityEngine.Event evt, UnityEngine.Matrix4x4 parentTransform, UnityEngine.Rect clippingRect, System.Boolean isComputingLayout, UnityEngine.Rect layoutSize, System.Action onGUIHandler, System.Boolean canAffectFocus) (at <0050475d167947ea9f166ad030caa84f>:0)
UnityEngine.UIElements.IMGUIContainer.HandleIMGUIEvent (UnityEngine.Event e, UnityEngine.Matrix4x4 worldTransform, UnityEngine.Rect clippingRect, System.Action onGUIHandler, System.Boolean canAffectFocus) (at <0050475d167947ea9f166ad030caa84f>:0)
UnityEngine.UIElements.IMGUIContainer.DoIMGUIRepaint () (at <0050475d167947ea9f166ad030caa84f>:0)
UnityEngine.UIElements.UIR.RenderChainCommand.ExecuteNonDrawMesh (UnityEngine.UIElements.UIR.DrawParams drawParams, System.Single pixelsPerPoint, System.Exception& immediateException) (at <0050475d167947ea9f166ad030caa84f>:0)
Rethrow as ImmediateModeException
UnityEngine.UIElements.UIR.RenderChain.Render () (at <0050475d167947ea9f166ad030caa84f>:0)
UnityEngine.UIElements.UIRRepaintUpdater.Update () (at <0050475d167947ea9f166ad030caa84f>:0)
UnityEngine.UIElements.VisualTreeUpdater.UpdateVisualTreePhase (UnityEngine.UIElements.VisualTreeUpdatePhase phase) (at <0050475d167947ea9f166ad030caa84f>:0)
UnityEngine.UIElements.Panel.UpdateForRepaint () (at <0050475d167947ea9f166ad030caa84f>:0)
UnityEngine.UIElements.Panel.Repaint (UnityEngine.Event e) (at <0050475d167947ea9f166ad030caa84f>:0)
UnityEngine.UIElements.UIElementsUtility.DoDispatch (UnityEngine.UIElements.BaseVisualElementPanel panel) (at <0050475d167947ea9f166ad030caa84f>:0)
UnityEngine.UIElements.UIElementsUtility.UnityEngine.UIElements.IUIElementsUtility.ProcessEvent (System.Int32 instanceID, System.IntPtr nativeEventPtr, System.Boolean& eventHandled) (at <0050475d167947ea9f166ad030caa84f>:0)
UnityEngine.UIElements.UIEventRegistration.ProcessEvent (System.Int32 instanceID, System.IntPtr nativeEventPtr) (at <0050475d167947ea9f166ad030caa84f>:0)
UnityEngine.UIElements.UIEventRegistration+<>c.<.cctor>b__1_2 (System.Int32 i, System.IntPtr ptr) (at <0050475d167947ea9f166ad030caa84f>:0)
UnityEngine.GUIUtility.ProcessEvent (System.Int32 instanceID, System.IntPtr nativeEventPtr, System.Boolean& result) (at <f8197c5efb504ab8a77daf7d0e9abc5e>:0)
One thing i can add is that after this point any new added blueprints dont work when editing.
(18-04-2021, 11:04 PM)Mmero Wrote: One thing i can add is that after this point any new added blueprints dont work when editing.
Hi Mmero,
Had another user report a similar issue on Unity 2020.2. What Unity version are you using?
(19-04-2021, 07:42 AM)josemendez Wrote: Hi Mmero,
2020.2.6f1
Any idea how to resolve this issue?
From my perspective i bought the asset that just doesnt work.
Assetstore page doesnt say anything about "this asset doesnt work in versions 2020.1 and above"
(19-04-2021, 08:32 PM)Mmero Wrote: Any idea how to resolve this issue?
It has been reported only very recently, so still figuring it out. Judging from the stack trace, the culprit is a variable that should be initialized but it isn't. That variable is initialized when the editor gets its OnEnable() called, so it should *always* be initialized. Coupled with the fact that this only happens in 2020.2 and up, makes it look like a bug in Unity. I hope to have more details today.
(19-04-2021, 08:32 PM)Mmero Wrote: From my perspective i bought the asset that just doesnt work.
I'm fully aware of this, my apologies. The asset is supposed to work in 2020.2 just fine. Will investigate and provide a patch asap.
So far I've been unable to reproduce this. Tried 2020.2.6f1 and 2020.3.0 without success.
The stack trace points to a NullRefException in this line:
currentProperty.OnSceneRepaint();
The only thing that can be null here is currentProperty. This grabs the first property in the properties list, initialized in the editor's  OnEnable():
properties.Add(new ObiBlueprintMass(this));
properties.Add(new ObiBlueprintRadius(this));
properties.Add(new ObiBlueprintLayer(this));
So as long as Unity is calling OnEnable() -as it should- there's literally no way currentProperty can be null.
- You mentioned this happens 5 seconds or so after opening the blueprint editor, is this correct?
- Can you share the mesh you're using to generate the blueprint?
Also, can you try resetting Unity's window layout (Window->Layouts->Reset All Layouts)? 2020.X has a fair share of layout-related editor issues, some of them have affected us in the past. Just to make sure this isn't layout relayed.
I upgraded the unity version and the problem doesn't show up Sonrisa
Now I'm having a problem with cloth properties but this is for another topic
One of those unsolved Unity mysteries  Huh  . I'd actually like to get this to happen to me so that I can investigate and fully understand the issue, but this one is slippery!
Glad you got it working though.  Let me know if I can help in any way. Sonrisa
Got the same (Unity 2019.4.22f1) found a working temporary fix:
Look at the code added by // SDP tag
ObiActorBluePrintEditor.cs
Selectable.cs (in Unity source code Unity.app/Contents/Resources/PackageManager/BuiltInPackages/com.unity.ugui/Runtime/UI/Core/Selectable.cs)
Can be useful if upgrading your Unity is not an option
