14-01-2021, 04:31 PM
I am developing a chemical experiment environment using VR.
My plan is below.
When user mixes liquid A and liquid B, after that, its mixed liquid is displayed as a percentage; 70% or more is "perfect", 40% or more is "successful", and under 39% is "Failed" respectively.
Also, if liquid A is mixed with liquid C, an explosion is happened and "Failed" is displayed.
However, I made, installed and runed the scripts, nothing happened on VR. I think the reason why I cannot get the collision between particles.
However, I am not sure how to modify the script.
If you know the solution. Could you assist me?
Reference: Obi Fluid's sample "Maze", "Obi Manual" http://obi.virtualmethodstudio.com/tutor...rials.html Assets I'm using: SteamVR Plugin, SAColliderBuilder, Obi Fluid Version of Unity: Unity 2019.4
I am looking forward to hearing your answer.
Sincerely yours,
My plan is below.
Sincerely yours,
using System.Collections;
using UnityEngine.UI;
using UnityEngine.Events;
[RequireComponent(typeof(ObiEmitter))]
public class Chemicalreaction : MonoBehaviour
[System.Serializable]
public class ScoreChangeEvent : UnityEvent<int, int> { }
public List<ParticleCollisionEvent> collisionEvents;
public ObiSolver solver;
public ObiEmitter emitterA;
public ObiEmitter emitterB;
public ObiEmitter emitterC;
public ObiCollider finishLine;
public Text completionLabel;
public Text mixLabel;
public Text finishLabel;
public Text Gameover;
HashSet<int> finishedParticles = new HashSet<int>();
HashSet<int> coloredParticles = new HashSet<int>();
void Start()
solver.OnParticleCollision += Solver_OnParticleCollision;
collisionEvents = new List<ParticleCollisionEvent>();
private void OnDestory()
solver.OnParticleCollision -= Solver_OnParticleCollision;
private void Solver_OnParticleCollision(ObiSolver s, Obi.ObiSolver.ObiCollisionEventArgs e)
if (contact.distance < 0.01f)
var col = world.colliderHandles[contact.other].owner;
if (emitterB.GetComponent<ObiEmitter>() == pa.actor)
if (coloredParticles.Add(contact.particle))
UpdateScore(finishedParticles.Count, coloredParticles.Count);
else if (emitterC.GetComponent<ObiEmitter>() == pa.actor)
Gameover.text = "Failed";
else if (finishLine == col)
if (finishedParticles.Add(contact.particle))
public void UpdateScore(int finishedParticles, int coloredParticles)
int completion = Mathf.CeilToInt(finishedParticles / 600.0f * 100);
int mix = Mathf.CeilToInt(coloredParticles / 600.0f * 100);
completionLabel.text = completion + "% Completed";
mixLabel.text = mix + "% Mixed";
if (completion > 50)
if (mix > 70)
finishLabel.text = "Perfect!";
else if (mix > 40)
finishLabel.text = "Successful";
else
finishLabel.text = "Failed";
finishLabel.gameObject.SetActive(true);
