Threads: 12
07-12-2020, 11:05 PM
(This post was last modified: 08-12-2020, 02:55 AM by emz06.)
Hey,
I just updated to the latest version, and I was using an older version from April.
Now I get this error for every solver in the scene on every frame.
Any idea what is wrong?
I tried to delete the whole Obi folder and reimported but it didn't help.
ArgumentNullException: Value cannot be null.
Parameter name: key
System.Collections.Generic.Dictionary`2[TKey,TValue].FindEntry (TKey key) (at <fb001e01371b4adca20013e0ac763896>:0)
System.Collections.Generic.Dictionary`2[TKey,TValue].TryGetValue (TKey key, TValue& value) (at <fb001e01371b4adca20013e0ac763896>:0)
Obi.ObiTriangleMeshContainer.GetOrCreateTriangleMesh (UnityEngine.Mesh source) (at Assets/Obi/Scripts/Common/Collisions/ObiTriangleMeshContainer.cs:78)
Obi.ObiColliderWorld.GetOrCreateTriangleMesh (UnityEngine.Mesh mesh) (at Assets/Obi/Scripts/Common/Collisions/ObiColliderWorld.cs:229)
Obi.ObiMeshShapeTracker.UpdateIfNeeded () (at Assets/Obi/Scripts/Common/Collisions/ColliderTrackers/Trackers3D/ObiMeshShapeTracker.cs:38)
Obi.ObiColliderBase.UpdateIfNeeded () (at Assets/Obi/Scripts/Common/Collisions/ObiColliderBase.cs:189)
Obi.ObiColliderWorld.UpdateWorld () (at Assets/Obi/Scripts/Common/Collisions/ObiColliderWorld.cs:362)
Obi.ObiUpdater.BeginStep (System.Single stepDeltaTime) (at Assets/Obi/Scripts/Common/Updaters/ObiUpdater.cs:40)
Obi.ObiFixedUpdater.FixedUpdate () (at Assets/Obi/Scripts/Common/Updaters/ObiFixedUpdater.cs:54)
Also, when I try to Build my project I get this. Any idea why this is happening?
Shader error in 'Obi/URP/Particles': failed to open source file: 'Packages/com.unity.render-pipelines.universal/ShaderLibrary/Core.hlsl' at Assets/Obi/Resources/ObiMaterials/URP/ObiLightingURP.cginc(5) (on metal)
Compiling Vertex program
Platform defines: UNITY_NO_DXT5nm UNITY_NO_RGBM UNITY_ENABLE_REFLECTION_BUFFERS UNITY_FRAMEBUFFER_FETCH_AVAILABLE UNITY_NO_SCREENSPACE_SHADOWS UNITY_PBS_USE_BRDF3 SHADER_API_MOBILE UNITY_HARDWARE_TIER1 UNITY_COLORSPACE_GAMMA UNITY_LIGHTMAP_DLDR_ENCODING
08-12-2020, 09:40 AM
(This post was last modified: 08-12-2020, 09:40 AM by josemendez.)
Can't reproduce the first error, either in a blank project or updating from 5.3 to 5.6.2. Make sure you don't have configurable enter play mode options enabled, as these aren't supported.
Regarding the shader error: if you're not using URP, you can just get rid of the Assets/Obi/Resources/ObiMaterials/URP folder. These materials are meant for URP support.
Threads: 12
(08-12-2020, 09:40 AM)josemendez Wrote: Hi there,
The null argument error only happens in my current scene. But it does not happen if I open the demo scenes, or if I create a new scene, and place my prefab'ed solver from the problematic scene.
Does that give a clue of what is wrong?
08-12-2020, 03:29 PM
(This post was last modified: 08-12-2020, 03:49 PM by josemendez.)
(08-12-2020, 03:26 PM)emz06 Wrote: The null argument error only happens in my current scene. But it does not happen if I open the demo scenes, or if I create a new scene, and place my prefab'ed solver from the problematic scene.
Do you have references to null meshes in your scene? For instance, a MeshCollider taking no mesh as input? I think this might be a bug in Obi, caused by null meshes being passed to the collider system.
Edit: this is a bug in Obi indeed. Having a MeshCollider with no mesh input in the scene triggers it. To fix it, modify the GetOrCreateTriangleMesh() method in ObiTriangleMeshContainer.cs so that it starts like this:
Quote:ObiTriangleMeshHandle handle = new ObiTriangleMeshHandle(null);
if (source != null && !handles.TryGetValue(source, out handle))
Edit2: seems like this fix isn't working properly in some cases. Will spend a bit more time investigating and get back with a more robust fix.
Thanks for reporting this!
Threads: 12
08-12-2020, 04:52 PM
(This post was last modified: 08-12-2020, 05:53 PM by emz06.)
(08-12-2020, 03:29 PM)josemendez Wrote: Do you have references to null meshes in your scene? For instance, a MeshCollider taking no mesh as input? I think this might be a bug in Obi, caused by null meshes being passed to the collider system.
Thanks for that.
I did check all my mesh colliders, and I didn't find one which was null.
Even with your modification, I am getting a NullReferenceException *at the same moment* that I press the Play button (that is: BEFORE the scene is played):
(then I get this exception once per frame)
Obi.ObiParticleRenderer.get_ParticleMeshes () (at Assets/Obi/Scripts/Common/Rendering/ObiParticleRenderer.cs:27)
Obi.FluidRenderingUtils.VolumeReconstruction (UnityEngine.Rendering.CommandBuffer cmd, Obi.FluidRenderingUtils+FluidRenderTargets renderTargets, UnityEngine.Material thickness_Material, UnityEngine.Material colorMaterial, Obi.ObiParticleRenderer[] renderers) (at Assets/Obi/Scripts/Fluid/Rendering/FluidRenderingUtils.cs:137)
Obi.ObiFluidRenderer.UpdateFluidRenderingCommandBuffer () (at Assets/Obi/Scripts/Fluid/Rendering/ObiFluidRenderer.cs:118)
Obi.ObiBaseFluidRenderer.OnPreRender () (at Assets/Obi/Scripts/Fluid/Rendering/ObiBaseFluidRenderer.cs:80)
UnityEngine.GUIUtility: ProcessEvent(Int32, IntPtr) (at /Users/bokken/buildslave/unity/build/Modules/IMGUI/GUIUtility.cs:197)
EDIT:
I think it has to do with the script ObiKinematicVelocities.cs, which seems to have been removed in the new version.
I was using this on one of the objects, because I had a fast moving platform, moving sideways, and I wanted to translate the particles on that platform.
Is there an alternative to ObiKinematicVelocities.cs?
08-12-2020, 06:04 PM
(This post was last modified: 08-12-2020, 06:05 PM by josemendez.)
(08-12-2020, 04:52 PM)emz06 Wrote: Thanks for that.
EDIT:
ObiKinematicVelocities is now part of the core engine. You should just remove it. See the changelog for 5.6.1:
Quote:## [5.6.1]
### Fixed
- Bug in Burst backend: solver bounding box size was typically underestimated.
- Bug in Burst backend: when using volume constraints: "InvalidOperationException: The NativeContainer ApplyVolumeConstraintsBatchJob.particleIndices has not been assigned or constructed"
- Bug in Burst backend: not releasing native arrays when empty solvers -with zero actors in them- are present in the scene.
- Bug in Oni backend: volume constraints not working properly when multiple actors are present in the solver.
- Fixed crash when using ObiLateUpdater or ObiLateFixedUpdater with the Burst backend.
- Reduced GC allocation in dynamic particle attachments.
- Fixed bug in Skin constraints, that caused them to fail restricting particle movement in certain circumstances.
### Changed
- Updated Oni iOS library to XCode 12.1. Make sure to use XCode 12.1 or up to build for iOS when using the Oni backend.
- ObiKinematicVelocities component has been removed. Its functionality is now built into the engine, and automatically used for kinematic rigidbodies.
### Added
- Sample ObiContactDispatcher component, that will call custom enter/stay/exit contact events.
- Support for multiple solvers in sample script in ObiContactGrabber.
- Added util LookAroundCamera component.
Threads: 12
Thanks for the clarification.
The problem seems to have disappeared.
I'm not sure what solved it, but I went to my camera, set the size of Particle Renderers to 0, then I added every emitter in the scene, one at a time, and played the scene every time.
For some reason, they started working again.
Thanks for your help!
