08-11-2017, 09:02 PM
Hi.
I have existing rope with couple on handlers on both of rope ends (attached to first and last rope particle).
I want to substitute them (or possibly only one of them with pin constraint).
I think handle can be removed/added with the help of disabling/enabling handle gameObject.
For adding ping constraint I'm launching some variations of following coroutine:
I was experimenting with Adding/Removing from solver and with pushing data back to solver without success.
I can see generated with script pin constraint in unity inspector, but it does nothing.
What am I missing?
Should I reinitialize rope somehow?
Thanks a lot.
private IEnumerator AttachHook(){
yield return 0;
// Pin both ends of the rope (this enables two-way interaction between character and rope):
ObiPinConstraints pinConstraints = obiRope.GetComponent<ObiPinConstraints>();
ObiPinConstraintBatch pinBatch = pinConstraints.GetBatches()[0] as ObiPinConstraintBatch;
// remove the constraints from the solver, because we cannot modify the constraints list while the solver is using it.
// pinConstraints.RemoveFromSolver(null);
// remove the first constraint.
// pinBatch.RemoveConstraint(0);
pinBatch.AddConstraint(obiRope.particleIndices[_obiParticleHandle.FirstParticleIndex], obiColliderToAttach, obiOffsetToAttach, 0);
// Add the rope to the solver to begin the simulation:
pinConstraints.AddToSolver(null);
// pinConstraints.PushDataToSolver();
What am I missing?
Thanks a lot.
