06-04-2020, 04:55 PM
(This post was last modified: 06-04-2020, 04:56 PM by josemendez.)
I'm unable to reproduce this. Do you have any control points selected? (actually if you have no points selected, the GUI properties are disabled and should appear grayed out, so there's definitely something weird going on here).
06-04-2020, 07:31 PM
(This post was last modified: 06-04-2020, 07:31 PM by josemendez.)
It's not the intended behavior, for sure, but I'm glad you got it working. Will try to reproduce and hopefully fix it. Thanks for reporting this!
07-04-2020, 09:06 AM
(This post was last modified: 07-04-2020, 09:15 AM by josemendez.)
Unable to reproduce on 2019.2.9f1, or 2019.3.8f1.
Are you able to reproduce this in a fresh project? Do you have any other assets installed that might make use of/modify the editor UI? Immediate mode GUI is basically a state machine, It wouldn't be the first time I've come across an asset that leaves the state corrupted, causing all sort of random issues in any GUI drawn after it. (AURA2 comes to mind, though I believe they fixed it in newer versions)
