Help  About the cloth generation script before execution
Pregunta
I'm trying to generate multiple fabrics using Obi.
I created it by referring to SackGenerator, RuntimeClothGenerator, etc., but there is a problem because initialization is not executed.
I want to execute initialization. what should I do?
I know how to generate it during execution, but how can I run it in an editor script before execution?
(10-10-2019, 10:33 AM)tukuyo Wrote: I'm trying to generate multiple fabrics using Obi.
I'd need to see what your current code is to be able to tell what's wrong.
(10-10-2019, 10:42 AM)josemendez Wrote: Hi,
Thank you for your quick reply.
The script is attached below.
The first is the Editor script.
The second is the part of the script that is run from the Editor script.
The third is a script attached to the generated Cloth object.
(In some places, comment out and Japanese is written, but don't worry.)
Best regards,
using System.Collections;
using UnityEditor;
[CustomEditor(typeof(Master))]
public class GenerateCloth : Editor
   public override void OnInspectorGUI()
       DrawDefaultInspector();
       Master script = (Master)target;
       if(!EditorApplication.isPlaying){
           if (GUILayout.Button("Genarete!!")){
               script.CreateCloth();
using UnityEngine.UI;
using System.IO;
using System.Linq;
public class Master : MonoBehaviour {
   // 布オブジェクトを持つ親
   [SerializeField]
   private GameObject testParent;
   [Header("=====基本布生成=====")]
   // 生成する布の大きさm と分割数
   [SerializeField]
    private float _scale = 1;
    [SerializeField]
    private int _resolution = 10;
   public Material outsideMaterial;
   public Material insideMaterial;
   public ObiSolver solver;
   public ObiMeshTopology topology;
   public bool useObi = false;
   public void CreateCloth()
       if(!useObi){
              // Processing when Obi is not used
       } else {
           int num = obisettings.Length;
           if(num <= 0) return;
           // テスト分オブジェクト生成
           for (int i = 0; i < num; i++)
               Mesh mesh = createMesh(_scale, _resolution);
               GameObject sheet = new GameObject("Sheet" + i, typeof(MeshFilter), typeof(SkinnedMeshRenderer));
               sheet.GetComponent<SkinnedMeshRenderer>().materials = new Material[] { outsideMaterial, insideMaterial };
               sheet.transform.parent = testParent.transform;
               sheet.transform.localPosition = Vector3.forward;
               sheet.tag = "sheet";
               sheet.AddComponent<ObiCloth>();
               genCloth generator = sheet.AddComponent<genCloth>();
               generator.mesh = mesh;
               generator.resolution = _resolution;
               generator.topology = topology;
               generator.solver = solver;
               generator.setUpObi();
using System;
[RequireComponent(typeof(MeshFilter))]
//[RequireComponent (typeof(MeshRenderer))]
[RequireComponent(typeof(SkinnedMeshRenderer))]
public class genCloth : MonoBehaviour
   public Mesh mesh;
   public SphereCollider virtualHand;
   public float Damping = 0;
   public float Stretching = 0;
   public float Bending = 0;
   public int resolution;
   public Vector3 Accelerration;
   private Cloth component;
   public ObiSolver solver;                /**< solver to add the sack to.*/
   public void Awake(){
       if(this.gameObject.GetComponent<ObiCloth>()){
           ObiCloth cloth = GetComponent<ObiCloth>();
           CoroutineJob job = new CoroutineJob();
           job.Start(cloth.GeneratePhysicRepresentationForMesh());
public void setUpObi() {
       if(mesh == null || topology == null){
           Debug.LogError("Either the mesh or the topology are null. You must provide a mesh and an empty topology asset in order to generate cloth.");
       var filter = GetComponent<MeshFilter>();
       filter.sharedMesh = mesh;
       var skin = GetComponent<SkinnedMeshRenderer>();
       skin.sharedMesh = mesh;
       topology.InputMesh = mesh;
       topology.Generate();
       cloth.Solver = solver;
       cloth.SharedTopology = topology;
       cloth.enabled = true;
       cloth.AddToSolver(null);
(12-10-2019, 04:35 PM)tukuyo Wrote: Thank you for your quick reply.
Best regards,
using UnityEditor;
using System.IO;
using System.Linq;
   // 布オブジェクトを持つ親
   [SerializeField]
   // 生成する布の大きさm と分割数
   [SerializeField]
   [SerializeField]
       if(!useObi){
       } else {
           // テスト分オブジェクト生成
using System;
   public Mesh mesh;
Hi.
cloth.GeneratePhysicRepresentationForMesh is a coroutine, and CoroutineJob() is meant to execute coroutines in the editor. Use StartCoroutine instead. See:
https://docs.unity3d.com/ScriptReference...utine.html
(12-10-2019, 05:12 PM)josemendez Wrote: Hi.
Thank you for your polite explanation and quick reply.
I would like to use StartCoroutine.
Thank you very much.
