27-02-2019, 02:37 PM
I am using obi collider, but the collider seem not to work correctly. What is wrong?
Help Obi collider
27-02-2019, 04:08 PM
(This post was last modified: 27-02-2019, 04:09 PM by josemendez.)
(27-02-2019, 02:37 PM)Richard Wrote: I am using obi collider, but the collider seem not to work correctly. What is wrong? The radius of your particles is too small. Use the particle editor to increase it (you can add a ObiParticleRenderer component to debug collisions). Alternatively, increase your collider's "thickness". See: http://obi.virtualmethodstudio.com/tutor...sions.html http://obi.virtualmethodstudio.com/tutor...iting.html http://obi.virtualmethodstudio.com/tutor...ering.html
09-03-2019, 10:53 PM
(27-02-2019, 04:08 PM)josemendez Wrote: The radius of your particles is too small. Use the particle editor to increase it (you can add a ObiParticleRenderer component to debug collisions). Alternatively, increase your collider's "thickness". See: Had the same issue. Collision were triggered but with no visible effect. Increasing the thickness did the trick. Thanks! |
« Next Oldest | Next Newest »
