Feedback Editor Customizable Category Names
Only a few lines of code, but I think this should already be part of the asset to support an SO where you can customize the ObiCategoryNames instead of modifying the source.
(18-01-2025, 03:39 PM)Jawsarn Wrote: Only a few lines of code, but I think this should already be part of the asset to support an SO where you can customize the ObiCategoryNames instead of modifying the source.
Thanks for the suggestion! We'll add support for custom category names in the editor in upcoming versions.
Great!
On a similar note, but which is more of a design choice, would be to support similarly to the Collision Materials, Collision Category Archetype, which can be assigned on Actors, Ropes CPs etc, instead of "inline" the category fitlers. Use case for this is to reuse same filters on e.g. rope starts/ends/actors, with easy modification in one place instead having to modifying each and every rope and collider.
