Hello. My project breaks and opens only in safe mode after installing Obi Rope. I believe it has something to do with Fluxy as I have it in the project too and one of the errors mentioned Fluxy. I've never had this error with Fluxy before.
I've deleted the Fluxy character controller folder in samples that produced the error, error disappeared, but I still get these 2 other errors, I'm stuck and the project is broken, unfortunately.
1. Assets\Obi\Scripts\Common\Backends\Burst\DataStructures\NativeMultilevelGrid.cs(74,46): error CS1061: 'UnsafeList<K>' does not contain a definition for 'length' and no accessible extension method 'length' accepting a first argument of type 'UnsafeList<K>' could be found (are you missing a using directive or an assembly reference?)
2. Failed to find entry-points:
Mono.Cecil.AssemblyResolutionException: Failed to resolve assembly: 'Obi.Editor, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null' ---> System.Exception: Failed to resolve assembly 'Obi.Editor, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null' in directories: C:\Program Files\Unity\Hub\Editor\2022.3.21f1\Editor\Data\MonoBleedingEdge\lib\mono\unityjit-win32
Full error makes flags this message and doesn't let me post it. So I can pm it to you if requested
Unity 2022.3.21
Unity 2022.3.21
