22-06-2022, 02:54 PM
I am trying to use Obi rope in Unity 2021.3.0f1 ( MacBook Pro (13-inch, M1, 2020) chip Apple M1 )
its showing the following errors -- >
1. DllNotFoundException: libOni assembly:<unknown assembly> type:<unknown type> member
null)
Obi.OniBackend.CreateSolver (Obi.ObiSolver solver, System.Int32 capacity) (at Assets/Obi/Scripts/Common/Backends/Oni/OniBackend.cs:17)
Obi.ObiSolver.Initialize () (at Assets/Obi/Scripts/Common/Solver/ObiSolver.cs:851)
Obi.ObiSolver.AddActor (Obi.ObiActor actor) (at Assets/Obi/Scripts/Common/Solver/ObiSolver.cs:1112)
Obi.ObiActor.AddToSolver () (at Assets/Obi/Scripts/Common/Actors/ObiActor.cs:348)
Obi.ObiActor.OnEnable () (at Assets/Obi/Scripts/Common/Actors/ObiActor.cs:323)
2. DllNotFoundException: libOni assembly:<unknown assembly> type:<unknown type> member
null)
Obi.OniColliderWorld.SetColliders (Obi.ObiNativeColliderShapeList shapes, Obi.ObiNativeAabbList bounds, Obi.ObiNativeAffineTransformList transforms, System.Int32 count) (at Assets/Obi/Scripts/Common/Backends/Oni/OniColliderWorld.cs:40)
Obi.ObiColliderWorld.UpdateWorld (System.Single deltaTime) (at Assets/Obi/Scripts/Common/Collisions/ObiColliderWorld.cs:388)
Obi.ObiUpdater.BeginStep (System.Single stepDeltaTime) (at Assets/Obi/Scripts/Common/Updaters/ObiUpdater.cs:56)
Obi.ObiFixedUpdater.FixedUpdate () (at Assets/Obi/Scripts/Common/Updaters/ObiFixedUpdater.cs:46)
I also tried following solution -->
The dll library it cannot find (because it’s not compatible with the M1 architecture) is just a fallback in case you haven’t installed the required Burst packages. Moreover, this fallback library is deprecated in will be removed in Obi 7.Make sure you’ve installed the Burst dependencies as per the manual:
Tried the following setup -->
[color=rgba(var(--sk_highlight,18,100,163),1)]http://obi.virtualmethodstudio.com/manual/6.3/backends.html#burst[/color]
In the above setup I am not getting the option of
JOBS -> Leaks detection -> Off
null)Obi.OniBackend.CreateSolver (Obi.ObiSolver solver, System.Int32 capacity) (at Assets/Obi/Scripts/Common/Backends/Oni/OniBackend.cs:17)
null)Obi.OniColliderWorld.SetColliders (Obi.ObiNativeColliderShapeList shapes, Obi.ObiNativeAabbList bounds, Obi.ObiNativeAffineTransformList transforms, System.Int32 count) (at Assets/Obi/Scripts/Common/Backends/Oni/OniColliderWorld.cs:40)
