| _aerodynamicsEnabled (defined in Obi.ObiRopeBase) | Obi.ObiRopeBase | protected |
| _drag (defined in Obi.ObiRopeBase) | Obi.ObiRopeBase | protected |
| _lift (defined in Obi.ObiRopeBase) | Obi.ObiRopeBase | protected |
| aerodynamicsEnabled | Obi.ObiRopeBase | |
| CalculateLength() | Obi.ObiRopeBase | |
| drag | Obi.ObiRopeBase | |
| elements | Obi.ObiRopeBase | |
| GetDeformableEdgeCount() (defined in Obi.ObiRopeBase) | Obi.ObiRopeBase | virtual |
| GetDrag(ObiAerodynamicConstraintsBatch batch, int constraintIndex) (defined in Obi.ObiRopeBase) | Obi.ObiRopeBase | |
| GetEdgeAt(float mu, out float elementMu) | Obi.ObiRopeBase | |
| GetElementAt(float mu, out float elementMu) | Obi.ObiRopeBase | |
| GetLift(ObiAerodynamicConstraintsBatch batch, int constraintIndex) (defined in Obi.ObiRopeBase) | Obi.ObiRopeBase | |
| lift | Obi.ObiRopeBase | |
| m_SelfCollisions (defined in Obi.ObiRopeBase) | Obi.ObiRopeBase | protected |
| OnDisable() (defined in Obi.ObiActor) | Obi.ObiActor | protectedvirtual |
| OnElementsGenerated (defined in Obi.ObiRopeBase) | Obi.ObiRopeBase | |
| OnEnable() (defined in Obi.ObiActor) | Obi.ObiActor | protectedvirtual |
| OnValidate() (defined in Obi.ObiActor) | Obi.ObiActor | protectedvirtual |
| path (defined in Obi.ObiRopeBase) | Obi.ObiRopeBase | |
| ProvideDeformableEdges(ObiNativeIntList deformableEdges) (defined in Obi.ObiRopeBase) | Obi.ObiRopeBase | virtual |
| ProvideDeformableTriangles(ObiNativeIntList deformableTriangles, ObiNativeVector2List deformableUVs) (defined in Obi.ObiActor) | Obi.ObiActor | virtual |
| RebuildConstraintsFromElements() | Obi.ObiRopeBase | virtual |
| RebuildElementsFromConstraints() | Obi.ObiRopeBase | |
| RebuildElementsFromConstraintsInternal() (defined in Obi.ObiRopeBase) | Obi.ObiRopeBase | protectedpure virtual |
| RecalculateRestLength() | Obi.ObiRopeBase | |
| RecalculateRestPositions() | Obi.ObiRopeBase | |
| RequestReadback() (defined in Obi.ObiActor) | Obi.ObiActor | virtual |
| restLength (defined in Obi.ObiRopeBase) | Obi.ObiRopeBase | |
| restLength_ (defined in Obi.ObiRopeBase) | Obi.ObiRopeBase | protected |
| SimulationEnd(float simulatedTime, float substepTime) (defined in Obi.ObiActor) | Obi.ObiActor | virtual |
| SimulationStart(float timeToSimulate, float substepTime) (defined in Obi.ObiActor) | Obi.ObiActor | virtual |
| sourceBlueprint | Obi.ObiActor | |
| usesOrientedParticles | Obi.ObiActor | |
