| _aerodynamicsEnabled (defined in Obi.ObiRopeBase) | Obi.ObiRopeBase | protected |
| _bendCompliance (defined in Obi.ObiRope) | Obi.ObiRope | protected |
| _bendConstraintsEnabled (defined in Obi.ObiRope) | Obi.ObiRope | protected |
| _distanceConstraintsEnabled (defined in Obi.ObiRope) | Obi.ObiRope | protected |
| _drag (defined in Obi.ObiRopeBase) | Obi.ObiRopeBase | protected |
| _lift (defined in Obi.ObiRopeBase) | Obi.ObiRopeBase | protected |
| _maxBending (defined in Obi.ObiRope) | Obi.ObiRope | protected |
| _maxCompression (defined in Obi.ObiRope) | Obi.ObiRope | protected |
| _plasticCreep (defined in Obi.ObiRope) | Obi.ObiRope | protected |
| _plasticYield (defined in Obi.ObiRope) | Obi.ObiRope | protected |
| _stretchCompliance (defined in Obi.ObiRope) | Obi.ObiRope | protected |
| _stretchingScale (defined in Obi.ObiRope) | Obi.ObiRope | protected |
| aerodynamicsEnabled | Obi.ObiRopeBase | |
| ApplyTearing(float substepTime) (defined in Obi.ObiRope) | Obi.ObiRope | protected |
| bendCompliance | Obi.ObiRope | |
| bendConstraintsEnabled | Obi.ObiRope | |
| CalculateLength() | Obi.ObiRopeBase | |
| distanceConstraintsEnabled | Obi.ObiRope | |
| drag | Obi.ObiRopeBase | |
| elements | Obi.ObiRopeBase | |
| GetDeformableEdgeCount() (defined in Obi.ObiRopeBase) | Obi.ObiRopeBase | virtual |
| GetDrag(ObiAerodynamicConstraintsBatch batch, int constraintIndex) (defined in Obi.ObiRopeBase) | Obi.ObiRopeBase | |
| GetEdgeAt(float mu, out float elementMu) | Obi.ObiRopeBase | |
| GetElementAt(float mu, out float elementMu) | Obi.ObiRopeBase | |
| GetLift(ObiAerodynamicConstraintsBatch batch, int constraintIndex) (defined in Obi.ObiRopeBase) | Obi.ObiRopeBase | |
| interParticleDistance | Obi.ObiRope | |
| lift | Obi.ObiRopeBase | |
| m_RopeBlueprint (defined in Obi.ObiRope) | Obi.ObiRope | protected |
| m_SelfCollisions (defined in Obi.ObiRopeBase) | Obi.ObiRopeBase | protected |
| maxBending | Obi.ObiRope | |
| maxCompression | Obi.ObiRope | |
| OnDisable() (defined in Obi.ObiActor) | Obi.ObiActor | protectedvirtual |
| OnElementsGenerated (defined in Obi.ObiRopeBase) | Obi.ObiRopeBase | |
| OnEnable() (defined in Obi.ObiActor) | Obi.ObiActor | protectedvirtual |
| OnRopeTorn | Obi.ObiRope | |
| OnValidate() (defined in Obi.ObiRope) | Obi.ObiRope | protectedvirtual |
| path (defined in Obi.ObiRopeBase) | Obi.ObiRopeBase | |
| plasticCreep | Obi.ObiRope | |
| plasticYield | Obi.ObiRope | |
| ProvideDeformableEdges(ObiNativeIntList deformableEdges) (defined in Obi.ObiRopeBase) | Obi.ObiRopeBase | virtual |
| ProvideDeformableTriangles(ObiNativeIntList deformableTriangles, ObiNativeVector2List deformableUVs) (defined in Obi.ObiActor) | Obi.ObiActor | virtual |
| RebuildConstraintsFromElements() | Obi.ObiRope | virtual |
| RebuildElementsFromConstraints() | Obi.ObiRopeBase | |
| RebuildElementsFromConstraintsInternal() (defined in Obi.ObiRope) | Obi.ObiRope | protectedvirtual |
| RecalculateRestLength() | Obi.ObiRopeBase | |
| RecalculateRestPositions() | Obi.ObiRopeBase | |
| RequestReadback() (defined in Obi.ObiActor) | Obi.ObiActor | virtual |
| restLength (defined in Obi.ObiRopeBase) | Obi.ObiRopeBase | |
| restLength_ (defined in Obi.ObiRopeBase) | Obi.ObiRopeBase | protected |
| ropeBlueprint (defined in Obi.ObiRope) | Obi.ObiRope | |
| RopeTornCallback(ObiRope rope, ObiRopeTornEventArgs tearInfo) (defined in Obi.ObiRope) | Obi.ObiRope | |
| selfCollisions | Obi.ObiRope | |
| SimulationEnd(float simulatedTime, float substepTime) (defined in Obi.ObiActor) | Obi.ObiActor | virtual |
| SimulationStart(float timeToSimulate, float substepTime) (defined in Obi.ObiRope) | Obi.ObiRope | virtual |
| sourceBlueprint (defined in Obi.ObiRope) | Obi.ObiRope | |
| stretchCompliance | Obi.ObiRope | |
| stretchingScale | Obi.ObiRope | |
| Tear(ObiStructuralElement element) | Obi.ObiRope | |
| tearingEnabled (defined in Obi.ObiRope) | Obi.ObiRope | |
| tearRate (defined in Obi.ObiRope) | Obi.ObiRope | |
| tearResistanceMultiplier | Obi.ObiRope | |
| usesOrientedParticles | Obi.ObiActor | |
