| ActivateAllConstraints() (defined in Obi.ObiConstraintsBatch) | Obi.ObiConstraintsBatch | |
| ActivateConstraint(int constraintIndex) (defined in Obi.ObiConstraintsBatch) | Obi.ObiConstraintsBatch | |
| activeConstraintCount (defined in Obi.ObiConstraintsBatch) | Obi.ObiConstraintsBatch | |
| AddConstraint(int solverIndex, ObiColliderBase body, Vector3 offset, Quaternion restDarboux, float linearCompliance, float rotationalCompliance) (defined in Obi.ObiPinConstraintsBatch) | Obi.ObiPinConstraintsBatch | |
| AddToSolver(ObiSolver solver) (defined in Obi.ObiPinConstraintsBatch) | Obi.ObiPinConstraintsBatch | virtual |
| Clear() (defined in Obi.ObiPinConstraintsBatch) | Obi.ObiPinConstraintsBatch | virtual |
| colliderIndices | Obi.ObiPinConstraintsBatch | |
| constraintCount (defined in Obi.ObiConstraintsBatch) | Obi.ObiConstraintsBatch | |
| constraintType (defined in Obi.ObiPinConstraintsBatch) | Obi.ObiPinConstraintsBatch | |
| CopyConstraint(ObiConstraintsBatch batch, int constraintIndex) (defined in Obi.ObiConstraintsBatch) | Obi.ObiConstraintsBatch | protectedvirtual |
| DeactivateAllConstraints() (defined in Obi.ObiConstraintsBatch) | Obi.ObiConstraintsBatch | |
| DeactivateConstraint(int constraintIndex) (defined in Obi.ObiConstraintsBatch) | Obi.ObiConstraintsBatch | |
| GetConstraintIndex(int constraintId) | Obi.ObiConstraintsBatch | |
| GetParticlesInvolved(int index, List< int > particles) (defined in Obi.ObiPinConstraintsBatch) | Obi.ObiPinConstraintsBatch | virtual |
| implementation (defined in Obi.ObiPinConstraintsBatch) | Obi.ObiPinConstraintsBatch | |
| initialActiveConstraintCount (defined in Obi.ObiConstraintsBatch) | Obi.ObiConstraintsBatch | |
| IsConstraintActive(int index) (defined in Obi.ObiConstraintsBatch) | Obi.ObiConstraintsBatch | |
| lambdas | Obi.ObiConstraintsBatch | |
| m_ActiveConstraintCount (defined in Obi.ObiConstraintsBatch) | Obi.ObiConstraintsBatch | protected |
| m_BatchImpl (defined in Obi.ObiPinConstraintsBatch) | Obi.ObiPinConstraintsBatch | protected |
| m_ConstraintCount (defined in Obi.ObiConstraintsBatch) | Obi.ObiConstraintsBatch | protected |
| m_IDs (defined in Obi.ObiConstraintsBatch) | Obi.ObiConstraintsBatch | protected |
| m_IDToIndex | Obi.ObiConstraintsBatch | protected |
| m_InitialActiveConstraintCount (defined in Obi.ObiConstraintsBatch) | Obi.ObiConstraintsBatch | protected |
| Merge(ObiActor actor, IObiConstraintsBatch other) (defined in Obi.ObiPinConstraintsBatch) | Obi.ObiPinConstraintsBatch | virtual |
| ObiPinConstraintsBatch(ObiPinConstraintsData constraints=null) (defined in Obi.ObiPinConstraintsBatch) | Obi.ObiPinConstraintsBatch | |
| offsets | Obi.ObiPinConstraintsBatch | |
| particleIndices | Obi.ObiConstraintsBatch | |
| ParticlesSwapped(int index, int newIndex) (defined in Obi.ObiConstraintsBatch) | Obi.ObiConstraintsBatch | |
| pinBodies | Obi.ObiPinConstraintsBatch | |
| RegisterConstraint() | Obi.ObiConstraintsBatch | protected |
| RemoveConstraint(int constraintIndex) (defined in Obi.ObiConstraintsBatch) | Obi.ObiConstraintsBatch | |
| RemoveFromSolver(ObiSolver solver) (defined in Obi.ObiPinConstraintsBatch) | Obi.ObiPinConstraintsBatch | virtual |
| restDarbouxVectors | Obi.ObiPinConstraintsBatch | |
| stiffnesses | Obi.ObiPinConstraintsBatch | |
| SwapConstraints(int sourceIndex, int destIndex) (defined in Obi.ObiPinConstraintsBatch) | Obi.ObiPinConstraintsBatch | protectedvirtual |
