| Initialize() (defined in Obi.ObiActorBlueprint) | Obi.ObiActorBlueprint | protectedpure virtual |
| inputMesh | Obi.ObiMeshBasedActorBlueprint | |
| rotation (defined in Obi.ObiMeshBasedActorBlueprint) | Obi.ObiMeshBasedActorBlueprint | |
| scale (defined in Obi.ObiMeshBasedActorBlueprint) | Obi.ObiMeshBasedActorBlueprint | |
